  4. Temp gauge trouble shooting
103 Posts 10 Posters 51.5k Views 1 Watching
    @terry-tz no it's temp I think it's just the way they are set they are all like it
    terry.tzT
    terry.tzT
    terry.tz
    yea you can measure temp with pressure @declan don't know how accurate it is low temps that what made me wonder but it's probably just inaccurate at low temps dou to chinessium
    • terry.tzT terry.tz
      @terry-tz 😒
      • terry.tzT
        terry.tzT
        terry.tz
        what temp your bike get up to anyway
          @terry-tz no idea
          terry.tzT 1 Reply Last reply
            @terry-tz no idea
            terry.tzT
            terry.tzT
            terry.tz
            @declan ???
              @declan ???
              @terry-tz I got no idea how hot it gets I have no way of knowing I haven't used it since installing that cap
                terry.tzT
                terry.tzT
                terry.tz
                @declan are ok
                  Also, when the bike is shut off, them temperature gauge isnt touching the water properly.
                  Mine was dead set at 20C yesterday, but so was actual temp.
                  • J Jens Eskildsen
                    @jens-eskildsen if you have the same one as me I'm certain that it will always be on 20 when cold
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      metals don't react very linearly at low and high temps this is a lie but not in a way that would be accurate in a small simple device or respond fast hence engine thermostats are sh!te I'm assuming they are made the same way so instead of opening they move the needle so it's probably just shit at low temps until like 40-50c total guess hope I'm not teaching to suck eggs I'm not knowledgeable on this subject just think it make's sense
                        Mine seems to work fine when tested, and very linear in movement, when compared to the one in the instrument.
                        They seem to follow each other fine.
                        For me, its well worth the few bucks.
                        Test the gauge in the frigde/freezer, or in boiling water.
                        • J Jens Eskildsen
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @jens-eskildsen I don't have one yet to test or I would out of curiosity I will anyway when I get one lol
                            Okay, will chill mine today.
                            Just to clarify, the item seems to work flawlessly, and follows the needle in the dash.
                            Its not important what it reads when the bike is cold and is shut of, but will test just to see 😃
                              #42
                              Just tested in my frigde, it shows 11C, acutal temp is 5C.
                              In the shed it showed 30C, which was just about the actual temp as the sun was shining.
                              So yeah, perhaps theres something about a slightly wrong reading (reading higher than it actually is) when cold. As I said, i didnt even notice, so nothing to worry about, I still think its nice to see actual temps in degrees, instead of just the needle.
                              • J Jens Eskildsen
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @jens-eskildsen cool for doing the test man it's not like that amount of miss reading is an issue anyway and for £5 what can we expect there cool looking and informative if you have the patients do a hot test to if not il do one when I get mine
                                  @terry-tz I payed 11 lol and @Jens-Eskildsen was yours on 20 when sitting idle like mine does?idle as in not running
                                    Around 20C just sitting, yeah... But again, thats not far from what it should be, as the actual temp is just in that neighbourhood
                                    declanD 2 Replies Last reply
                                    • J Jens Eskildsen
                                      @jens-eskildsen I got it up to about 85 today
                                        terry.tzT
                                        terry.tzT
                                        terry.tz
                                        @declan 👍
                                        • J Jens Eskildsen
                                          @jens-eskildsen I'm running a test on mine on a hot day it said I was on 95 when I got back that's too hot so I'm gonna boil it and see if it off and also in cold water it still reads 20
