  4. Temp gauge trouble shooting
103 Posts 10 Posters 51.5k Views 1 Watching
  • terry.tzT terry.tz
    ???? I'm confused at what your asking him
    Stone cold it sits on 20.c every pic I can find shows the needle on exactly that
      Havent noticed, but I tested at boiling temp and it was spot on.
      • J Jens Eskildsen
        @jens-eskildsen mind looking for me when you can?
          Yeah, problem is, its often around 20C in my workshop.
          • J Jens Eskildsen
            @jens-eskildsen some help you are 😂😂😂 np man just let me know if you find anything out
            terry.tzT 1 Reply Last reply
              terry.tzT
              terry.tzT
              terry.tz
              @declan maybe it's a slight miss measure they are made in China and cost next to nothing do they measured by pressure
                @terry-tz no it's temp I think it's just the way they are set they are all like it
                  terry.tzT
                  terry.tzT
                  terry.tz
                  yea you can measure temp with pressure @declan don't know how accurate it is low temps that what made me wonder but it's probably just inaccurate at low temps dou to chinessium
                    @terry-tz 😒
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      what temp your bike get up to anyway
                        @terry-tz no idea
                          @terry-tz no idea
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @declan ???
                            @declan ???
                            @terry-tz I got no idea how hot it gets I have no way of knowing I haven't used it since installing that cap
                              terry.tzT
                              terry.tzT
                              terry.tz
                              @declan are ok
                                Also, when the bike is shut off, them temperature gauge isnt touching the water properly.
                                Mine was dead set at 20C yesterday, but so was actual temp.
                                • J Jens Eskildsen
                                  @jens-eskildsen if you have the same one as me I'm certain that it will always be on 20 when cold
                                  • terry.tzT
                                    terry.tzT
                                    terry.tz
                                    metals don't react very linearly at low and high temps this is a lie but not in a way that would be accurate in a small simple device or respond fast hence engine thermostats are sh!te I'm assuming they are made the same way so instead of opening they move the needle so it's probably just shit at low temps until like 40-50c total guess hope I'm not teaching to suck eggs I'm not knowledgeable on this subject just think it make's sense
                                      Mine seems to work fine when tested, and very linear in movement, when compared to the one in the instrument.
                                      They seem to follow each other fine.
                                      For me, its well worth the few bucks.
                                      Test the gauge in the frigde/freezer, or in boiling water.
                                      • J Jens Eskildsen
                                        terry.tzT
                                        terry.tzT
                                        terry.tz
                                        @jens-eskildsen I don't have one yet to test or I would out of curiosity I will anyway when I get one lol
                                          Okay, will chill mine today.
                                          Just to clarify, the item seems to work flawlessly, and follows the needle in the dash.
                                          Its not important what it reads when the bike is cold and is shut of, but will test just to see 😃
