  3. Other
  4. nsr125 help
nsr125 help
39 Posts 5 Posters 29.1k Views 1 Watching
  • mad73M
    mad73M
    mad73
    yeah got the correct full power jets , I think its a carb / fuel prob but will check every thing again
    • CarlosrexxC
      CarlosrexxC
      Carlosrexx
      Could be a spark issue too, it sounds asif the spark is being retarded at that point. Could be the cap or the coil breaking down and then working again at high revs! Just a suggestion
      • mad73M
        mad73M
        mad73
        ok had a little play today , carb clean everything looks right , checked to see if the plug is sparking ok and it looks a little strange to me when I hold the plug against the head nut no spark until I lift it off a little and it sparks between the plug and nut ( orange ) but looks to have a blue spark in the plug gap is this right as ive only ever seen a blue spark in the plug gap , is this a coil problem ? cap or lead ?
        • mad73M
          mad73M
          mad73
          ok bought a new coil and iridium plug to see if this sorts the problem out will fit tomorrow if I get home in time from work , this might sound like a silly question but how do u fit the cap to the lead do u just push it on , never fitted a new cap and lead b4
          ConnorDTRC 1 Reply Last reply
          • mad73M mad73
            ConnorDTRC
            ConnorDTRC
            ConnorDTR
            @mad73 The cap screws onto the lead, quite odd to me at first as i had never done one. But when you see it you'll understand
            • mad73M
              mad73M
              mad73
              changed the cap plug and lead and started straight away thank f'@=k just needs mot now , took for a quick spin up the road all seems fine cant really test properly as needs running in , QUESTION its running a kph to mph converter does this mean the trip meter will show miles or will it still run up in kilometers and what sort of mileage or kilometers should u run new piston and rings in I was thinking about 150 miles ?
              thanks for every ones advice hopefully soon have a dt and can pick every ones brains some more also once I dig my yzf out the garage il stick some pics up of that project as well
              • mad73M
                mad73M
                mad73
                how do I stick a pic up copy and paste don't work
                • mad73M mad73
                  @mad73
                  https://www.dt125r.co.uk/topic/5/embedding-images
                  I wrote this up there.
                  • mad73M
                    mad73M
                    mad73
                    does the pic need to be on photobucket or something can I not get them out of my pics on the laptop ?
                    • mad73M mad73
                      @mad73 Correct. You need to upload them to Photobucket.
                      This forum can host its own photos. I could enable the forum so that we could upload photos to it.
                      Draw back is that this forum is being hosted from my house, on one of these!
                      http://cdn1.alphr.com/sites/alphr/files/6/14/raspberry_pi_b_2_0_0.jpg
                      And I only have a 32Gb SD card for it.
                      SD cards are notourious for failing. I back the forum up to my HDD every week. But when it fails, we are going to lose a weeks worth of posts 😞
                      Sorry but the forum isn't busy enough to warrant paying hosting company.
                      • mad73M
                        mad73M
                        mad73
                        no probs I understand , I have a photobucket account any way so I just put them on there then put on here
                        thanks
                        • mad73M
                          mad73M
                          mad73
                          • mad73M
                            mad73M
                            mad73
                            http://i286.photobucket.com/albums/ll115/mad73_2008/ngy_zps3azqdfmn.jpg
                            • mad73M
                              mad73M
                              mad73
                              not sure wot happened with the pic but the link works
                              do have side fairings wont put them on till I no he aint gona drop it
                              • mad73M mad73
                                Please read:
                                http://192.168.0.2/topic/5/embedding-images
                                If you're still having problems open up another thread.
                                • mad73M
                                  mad73M
                                  mad73
                                  read it, think ive got it now will open a new thread and see if I can get it right lol
                                  • mad73M mad73
                                    @mad73 you are not the only one. A lot of people seem confused. Adding tags and what not. The internets moved on since the 90's lol. Just paste the location of the image and node will do the rest.
                                    • mad73M
                                      mad73M
                                      mad73
                                      ok son went out on the nsr the other night and said its not running right so I took it for a spin and its hard to pull away on it its bogging down quite a bit quite dangerous pulling out of junctions but once moving all seems good, also fork sill is leaking which aint much of a prob I changed them a couple of months ago must not of put it in right as the other side is good
                                      any one got any ideas wot to look for with the bogging jets are correct
                                        Sounds like way too much air. Tell me does it sound quite deep when you rev it.
                                        In neutral after its warm, when you blip the throttle does it respond instantly.
                                        Like this numpty here
                                        https://youtu.be/MC5sf4Cx4o4
                                        Says aww 99 octane fuel killed my bike. Uhmm no mate, you can clearly here the snorkel is not in the air box. Clear as day. I don't understand why people remove them lol
                                        mad73M 1 Reply Last reply
                                        • CarlosrexxC Carlosrexx
                                          I had a 'full power' NSR foxeye j22 j think it was. Although I never had any problems like yours, the powervalve would stop working all the time and would retard the engine. Sounds similar to what you're experiencing, I just ended up pinning the valve wide open and it never gave me an issue again.
                                          I'm not saying this is your solution, but it would be something I would take a look at regarding the running issues. With regards to PSI and compression, definitely check everything is bolted down to correct torque settings. Double check everything, make sure the carb is installed tight, no air leaks, proper float movement and clear jets. I know it's all simple stuff but sometimes stuff gets overlooked and it's the simplest thing that's stopping the bike from working.
                                          http://i1227.photobucket.com/albums/ee433/RV02-Sachs/NSR 125/ADA2BEBF-043A-46C8-9B71-7A61B3F637ED.jpg
                                          mad73M
                                          mad73M
                                          mad73
                                          how would I pin open the power valve ? might try this
