  3. Other
  4. nsr125 help
nsr125 help
39 Posts 5 Posters 28.5k Views 1 Watching
  • mad73M
    mad73M
    mad73
    how do I stick a pic up copy and paste don't work
    • mad73M mad73
      @mad73
      https://www.dt125r.co.uk/topic/5/embedding-images
      I wrote this up there.
      • mad73M
        mad73M
        mad73
        does the pic need to be on photobucket or something can I not get them out of my pics on the laptop ?
        • mad73M mad73
          @mad73 Correct. You need to upload them to Photobucket.
          This forum can host its own photos. I could enable the forum so that we could upload photos to it.
          Draw back is that this forum is being hosted from my house, on one of these!
          http://cdn1.alphr.com/sites/alphr/files/6/14/raspberry_pi_b_2_0_0.jpg
          And I only have a 32Gb SD card for it.
          SD cards are notourious for failing. I back the forum up to my HDD every week. But when it fails, we are going to lose a weeks worth of posts 😞
          Sorry but the forum isn't busy enough to warrant paying hosting company.
          • mad73M
            mad73M
            mad73
            no probs I understand , I have a photobucket account any way so I just put them on there then put on here
            thanks
            • mad73M
              mad73M
              mad73
              • mad73M
                mad73M
                mad73
                http://i286.photobucket.com/albums/ll115/mad73_2008/ngy_zps3azqdfmn.jpg
                • mad73M
                  mad73M
                  mad73
                  not sure wot happened with the pic but the link works
                  do have side fairings wont put them on till I no he aint gona drop it
                  • mad73M mad73
                    Please read:
                    http://192.168.0.2/topic/5/embedding-images
                    If you're still having problems open up another thread.
                    • mad73M
                      mad73M
                      mad73
                      read it, think ive got it now will open a new thread and see if I can get it right lol
                      • mad73M mad73
                        @mad73 you are not the only one. A lot of people seem confused. Adding tags and what not. The internets moved on since the 90's lol. Just paste the location of the image and node will do the rest.
                        • mad73M
                          mad73M
                          mad73
                          ok son went out on the nsr the other night and said its not running right so I took it for a spin and its hard to pull away on it its bogging down quite a bit quite dangerous pulling out of junctions but once moving all seems good, also fork sill is leaking which aint much of a prob I changed them a couple of months ago must not of put it in right as the other side is good
                          any one got any ideas wot to look for with the bogging jets are correct
                            Sounds like way too much air. Tell me does it sound quite deep when you rev it.
                            In neutral after its warm, when you blip the throttle does it respond instantly.
                            Like this numpty here
                            https://youtu.be/MC5sf4Cx4o4
                            Says aww 99 octane fuel killed my bike. Uhmm no mate, you can clearly here the snorkel is not in the air box. Clear as day. I don't understand why people remove them lol
                            mad73M 1 Reply Last reply
                            • CarlosrexxC Carlosrexx
                              I had a 'full power' NSR foxeye j22 j think it was. Although I never had any problems like yours, the powervalve would stop working all the time and would retard the engine. Sounds similar to what you're experiencing, I just ended up pinning the valve wide open and it never gave me an issue again.
                              I'm not saying this is your solution, but it would be something I would take a look at regarding the running issues. With regards to PSI and compression, definitely check everything is bolted down to correct torque settings. Double check everything, make sure the carb is installed tight, no air leaks, proper float movement and clear jets. I know it's all simple stuff but sometimes stuff gets overlooked and it's the simplest thing that's stopping the bike from working.
                              http://i1227.photobucket.com/albums/ee433/RV02-Sachs/NSR 125/ADA2BEBF-043A-46C8-9B71-7A61B3F637ED.jpg
                              mad73M
                              mad73M
                              mad73
                              how would I pin open the power valve ? might try this
                              • mad73M mad73
                                @mad73 pining the valve open will make things much worse.
                                If the bike is derestricted then it will want a fully operational powervalve
                                • mad73M
                                  mad73M
                                  mad73
                                  yeah fully derestricted its just pulling away where it seems to have a prob
                                    mad73M
                                    mad73M
                                    mad73
                                    @Calum a little bit like that , will have to try and get a video up of it , have to slip the clutch to get it to pull then seems fine , hasn't got great response when revving from idle ,
                                      Sounds to me like too much air, or the air flow is stalling.
                                      • mad73M
                                        mad73M
                                        mad73
                                        How would I sort that ?
                                          Make sure the snorkel is in there and that there are no sharp turns in the inlet Tracy. It's the bend into the air box that stalls air flow. Hence why snorkels are a must.
