  4. Temp gauge trouble shooting
103 Posts 10 Posters 51.5k Views 1 Watching
  • tunertomT tunertom
    @jens-eskildsen sorry to be the one to tell you this, but for one, you have the fan blowing the radiator the wrong way, rendering it useless as soon as you start to move
    secondly, pc fans are useless in vehicle application, they offer literally nowhere near the amount of airflow that moving even at 5mph provides. typically a PC is generating 150w of heat or less, thats 0.15kw, whereas a bike such as this is making hundreds of times more heat.
    you need an automotive fan to make an ounce of difference
    @tunertom You can pull air through the radiator no problems.
      @tunertom the fan on my triumph is behind the radiator, as is the one on my aprilia.
        Tom, I know, as I said, it was a test to see if it would fit.
        Its mounted on the right side tho, and its supposed to suck air, not blow it, so it pulls air through the radiator.
        • J Jens Eskildsen
          @jens-eskildsen yeah in my mechanics course we were told that some fans suck air through the radiator fins and others blow it through guess it doesent really matter
            Fan is protected a bit by fitting it on the backside
            • J Jens Eskildsen
              @jens-eskildsen but it's harder to fit and gets in the way more and then you can't see it
              • tunertomT
                tunertomT
                tunertom
                wrote on last edited by tunertom
                #99
                youve got the fan blowing towards the front of the bike... i didnt say it was in the wrong place i said its massively underpowered for application and its blowing the wrong way, its fighting the direction of the wind!
                as you can see..
                https://www.howtogeek.com/wp-content/uploads/2017/04/xopen-grille.png.pagespeed.gp+jp+jw+pj+ws+js+rj+rp+rw+ri+cp+md.ic.YEPgZw8Mwr.jpg
                  And I answered "I know that", and described in detail that it was only a testfitting.
                  I got it for free, and now have the wiring sorted for a proper fan, and know what dimension will fit.
                  Lets move along, shall we?
                  tunertomT 1 Reply Last reply
                  • J Jens Eskildsen
                    tunertomT
                    tunertomT
                    tunertom
                    @jens-eskildsen said in Temp gauge trouble shooting:
                    wouldnt a tape measure or an engineers rule, to measure the width of the radiator core not been sufficient to see what size of automotive fan you need, be better than bodging computer components onto it?
                      @tunertom not really since I have neither of those but now I know the dimensions I need just in case I come across one
                        Norwp, I needed to make sure that I could physically mount it to the radiator aswell.
                        But thanks for your concern 😂
