Inlet rubber3bn/3et
Stripped the 88 bike down and removed inlet rubber in preparation for new one, compared to 89 inlet rubber and there are differences. The 88 is marked 3bn and the 89 3et, the inlet to reeds is different as is the length on top of the inlet from bottle stub to carb mount, have not tried in situ but waiting for new one to arrive, is one inlet wrong or natural progression, and are there different carb to Air box rubbers? Carb is very tight fit with 3bn inlet and 3et looks shorter, both bottles the same.
Having difficulties uploading pics but will keep trying. -
Is it to accommodate the additional boost bottle / intake silencer on the later models? Did this addition make the airbox to carb rubber longer??
Checked on csm l, part nos for 88 and 89 bikes differ, as does the joint between the air box and carb, no extra bottle and yet to see one? Can you post pics of it?
Resized photos but still could not upload, said I did not have permission? New post uploaded at second attempt? Not worried, got there in the end, thanks Calum -
Cmon boys... you should know this,
88 3BN' inlet is for the VM26ss Mikuni, that was what the DT125R came out with,
Later updated to 3ET, a 200R code, using the TM28ss Mikuni flatslide.
The second YIES bottle towards the airbox wasn't introduced until 1999'
@darty that would explain it, I think mine had the flat side retro fitted and would have had the earlier carb to start with. Rubber joint to Air box later one and just the crankcase joint wrong one. Have the 3et from the 89 bike so I am going to fit that for now and reorder, thanks for the advice, now you have pointed it out it's clear. Appreciated, consider me told!
@darty Yeah I was going to put this, but didn't they run the VM26 up until like 96 or something.
All fitted,just as well, UPS never turned up with the new one from csm l, then sent email saying I was not in when delivery attempted at 4.59. Bulls##t! I was working on bike right by front door! Long story short coming Saturday after phone argument, driver tried to deliver to no 5, I live at no 9. Every fk'd up delivery I get is UPS, even their app is garbage. Bike starts and runs fine, a lot easier to fit carb as well with the correct inlet.
That is the correct set, I had the flatside carb with the 3bn inlet meant for the first edition carb, hard to fit carb
@oldman since you have stripped these bikes down a lot can you help me out with figuring out a connector I can’t find where it should go to I’ll creat a post thanks
@oldman Power Jets are awesome.
Basically when the bike is at a decent load but not accelerating, it soesn't need to use all of the main jet as that is too much fuel, the power jet instead takes over which uses slightly less fuel and has a leaner mixture.
They are not there on all carbs.
