  3. Inlet rubber3bn/3et
Inlet rubber3bn/3et
31 Posts 7 Posters 6.1k Views 1 Watching
  • ricky0115R ricky0115
    Slightly of topic but the same part of the engine, is the gasket on the inlet a rubber one? There’s a rubber one on mine and it has an air leak, I remember on my other engine it was the cereal box type
    @ricky0115 It should be a paper type, quite common for these to let air in here when botched.
    ricky0115R 1 Reply Last reply
      ricky0115R Offline
      ricky0115R Offline
      ricky0115
      @calum god damn, the bike should run without the choke when I get that replaced then. Fingers crossed! Cheers
        @ricky0115 Use Athena, or OEM gaskets only.
        You can get some paper gasket adhesive to just ensure it's properly sealed. It's what I've used on my engines.
          ricky0115R Offline
          ricky0115R Offline
          ricky0115
          @calum where’s the best place to get Athena gaskets? I remember pricing up OEM on Fowler’s for the top end was like £40 for 2 gaskets
          • O Offline
            O Offline
            Just received set for the 89 bike, ordered via ebay, £20 something, used before on the 88, athena the way to go
            • O oldman
              ricky0115R Offline
              ricky0115R Offline
              ricky0115
              @oldman cheers mate!
                @ricky0115 For gaskets and obtaining authentic genuine athena gaskets. Choose none other than PJME.
                But personal preference. I use eBay for almost everything else.
                  ricky0115R Offline
                  ricky0115R Offline
                  ricky0115
                  @calum thanks, also which adhesive would you recommend?
                    @ricky0115 https://www.pjme.co.uk/acatalog/Yamaha_DT125R_Tools___Workshop_Equipment_.html
                    Loctite Adhesive Spray.
                    Bought that like 5 years ago and still use it today.
                    People will no doubt say it's unnecessary. All I can say is I've only built engines with it and never had any problems. But I'll admit it's potentially over cautious.
                      ricky0115R Offline
                      ricky0115R Offline
                      ricky0115
                      @calum it was made for a reason why not use it! Especially on that annoying gasket on top of the carb
                        @ricky0115 don’t use rtv silicone it ends up in your reed cage
