Water pump damage
@ricky0115 Rust inhibitor
I have a new pump seal to go on but don't think it will last long with that shaft (if at all) , ordered replacement, there is a polished surface on the shaft that's destroyed, very little left.,don't know if it is a coating but tried polishing rough surface down but no good. Not willing to risk a leak.
It's not the end of the world, the pitting can be welded up then reground out, probably cheaper to buy a new impeller.
Or you could turn the impeller down on a lathe and create a press fit shim onto the shaft.
You know, in the event the part is discontinued...
