  4. Dt don’t work with its own fuel tank
11 Posts 3 Posters 2.1k Views
  • declanD Offline
    I’m so confused I put an am6 fuel tank on it with pre mix and it runs like a dream I put its own fuel tank on and after a few second the revs go up to 5k wtf is going on both have the same batch of petrol no additives
    • J Offline
      J Offline
      Jens Eskildsen
      Check the fuelvalve and the filters in it. Also make sure fuelline has no kinks, and no blocked fuelfilter.
      declanD 2 Replies Last reply
      • J Jens Eskildsen
        This post is deleted!
        • J Jens Eskildsen
          @jens-eskildsen so if the flow is blocked I get a high idle?
            @declan It'll do that if the bike runs really lean, but should cut out pretty quickly.
            I'd check the petcock as well. Ensure nothing is blocked.
              @calum I’ll pull it off tomorrow and will update you
              • J Offline
                J Offline
                Jens Eskildsen
                Blocked fuel = lean = high idle, so yeah.
                • J Jens Eskildsen
                  @jens-eskildsen so I took it out and there was dog hair in the tank but tbh it didn’t look too bad I might add I was accidentally running it on reserve all this time as I didn’t know which way was which so I blew through the “on” position and it was a lot more restrictive than I would have thought is this normal?, I then sprayed wd40 through there to hopefully clear any bits our then plopped it on and runs pretty good
                  • J Offline
                    J Offline
                    Jens Eskildsen
                    There should be a steady flow, and it should be the same in "on" af "res" setting.
                    Did you disassemble the petcock entirely?
                    • J Jens Eskildsen
                      @jens-eskildsen no it was stubborn but the bikes running great I’ll link a quick video
                        @declan https://youtu.be/r9pFrkpKKmo
                        The fuel is flowing steady
