  3. Pv adjustment help
Pv adjustment help
42 Posts 6 Posters 7.8k Views
  • SpannersS Spanners
    @calum
    We cover the clutch plates in the gearbox oil before installing them.
    It was in accordance with the Haynes manual.
    Should they have been soaked 24 hours?
    If so, what are the implications of not doing this?
    Have they not been soaking in the gearbox oil since installation?
    How do l stop the clutch slipping from now or when it wears will it natural gather more grip when the high spots wear?
    If not I’ve got a dangerous reving rocket! Ho-ho!
    F Offline
    F Offline
    @spanners have you adjusted the lever properly as per the manual? Could just be that it's set up wrong
    SpannersS 1 Reply Last reply
      @calum
      @spanners no it must be 24 hrs the implications are you will burn up your friction material they won’t soak as the oil goes to the sump and does not sit in the clutch cover
        SpannersS Offline
        SpannersS Offline
        Spanners
        @declan
        Oh bugger!
        • F finnerz89
          SpannersS Offline
          SpannersS Offline
          Spanners
          @finnerz89
          The bike apparently had a top end rebuild before l got it so l have not messed with anything to do with that. I will have a read and investigate tomorrow.
          Thank you for your help!
          F 1 Reply Last reply
            @finnerz89
            F Offline
            F Offline
            @spanners you should have about 3mm of free play at the lever as a rough figure
              Could be the clutch springs not torqued up properly.
                SpannersS Offline
                SpannersS Offline
                Spanners
                @calum
                I bought a full clutch kit we replaced everything.
                All springs are new and we adjusted it to the best of our knowledge and skill.
                Maybe the problem was with the repairers! Ha-ha!
                Clutch seems pretty solid apart from the power valve, you would have thought if it was slipping, it would do it through all the gears?
                I’ll get it up to full speed in 5th to see if it slips, then back to the old drawing board...... 😪
                • O Offline
                  O Offline
                  It's frustrating innit! Just as you think the end is near something else crops up! Good luck and hope you find the problem quickly,
                    @calum
                    F Offline
                    F Offline
                    @spanners it's more likely to do it in the higher gears.
                    I'd follow the Haynes manual procedure for setting up the clutch, then worry about the power valve after.
                    • F finnerz89
                      @finnerz89 It's more likely to do it under load in the lower gears, where the ratios are smaller and you're trying to accelerate. I would have thought.
                      declanD F 2 Replies Last reply
                        @calum yeah I would agree with that after all it’s where the most torque is
                          F Offline
                          F Offline
                          @calum in my experience it does it in higher gears when you're accelerating. At least that's what it did on my 650 and 1200
                          • F finnerz89
                            @finnerz89 It'll slip under load. So in the higher gears I guess you will be exerting more load onto the gearbox,
                              F Offline
                              F Offline
                              @calum yeah. The way I've always checked to see if a clutch is slipping is roll off the throttle in fifth or top, then snap the throttle back open. If it's going to slip then that's when it'll do it.
                              With a 2 stroke it's obviously a bit different, hitting the powerband would replicate that though I guess.
                              Much higher load on the engine in the higher gears
                              • J Offline
                                J Offline
                                Jens Eskildsen
                                I have never soaked clutchplates for 24, nor seen anyone do it.
                                Just assemle with a coat of oil will do the trick.
                                And yes, clutches are more prone to slip in higher gear, because the load on it is way higher.
                                • SpannersS Offline
                                  SpannersS Offline
                                  Spanners
                                  All! Big thanks for all of your replies and assistance.
                                  My clutch problem was indeed a adjustment issue, half a turn on handlebar adjuster.
                                  I guess soaking them for 24 hours would be better, but according to the Haynes manual not necessary as it just says cover them in the gearbox oil prior to installation.
                                  But god darn it is a rocket for a 125cc! Considering l have a 700cc bike it still made me smile as it squirted up to 70mph! Ho-ho!
                                  But l have to say l had to push her home, l now have another problem!
                                  She died on me......😪
                                  Starts all fine, put her in gear and she just dies!
                                  What the cluck could be causing this?
                                  P.S l am not gonna give up on this bike now, as it is practically new with all the parts I’ve changed!
                                  Again that’s in advance for all of your help!
                                    @spanners usually the kickstand switch
                                      SpannersS Offline
                                      SpannersS Offline
                                      Spanners
                                      @declan
                                      Thanks, l found a post from earlier this year with a guy having the same trouble.
                                      Unbelievable a little switch can cause much trouble. Should have a light to say the circuit is broken.
                                      Been years since l pushed a motorcycle home! Ha-ha! 😂👍
                                        @declan
                                        @spanners it happens lol
                                          @calum it’s playing up again out of the blue I had to blindly adjust pv when I was out got it going properly after a bit went through a bit of water and then it started playing up Again I did wash the bike yesterday so I think it’s probably water the wires for the stator are exposed where they go into the cover Any ideas otherwise
