  3. Carburetor
  4. Dt125 mikuni carb
Dt125 mikuni carb
37 Posts 4 Posters 11.4k Views
  • Irongamer727I
    Irongamer727I
    Does the later mikuni carbs have a power jet? What does that do? Anyone know where I can find proper pilot jets for a Dt125x? Size 27.5 is wanted.
    • K
      K
      kevin
      You can get ebc brand pilot jets on eBay. They work fine.
      The power jet system takes fuel directly from the float bowl via the grey pipe on the side of the carb, often gets blocked and stops working. It’s a bit of a rough and ready system for extra power when the throttle is fully open.
      • K
        K
        kevin
        It’s also worth remembering that carburettors like still air, that’s why the air box is so big, so if you have that strange bottle on the side of the pipe that connects the air box to the carb, it needs blocking as it’s designed to disrupt air flow as a form of restriction.
        • K kevin
          Irongamer727I
          Irongamer727I
          @kevin no it's not restrictive, it's meant to fill up blind spots
          • Irongamer727I
            Irongamer727I
            Could you link some pilot jets?
            • K
              K
              kevin
              :311670245943 eBay item no.
              No I didn’t mean the yeis bottle I was referring to the other one on the air box side of the carb.
              • K kevin
                Irongamer727I
                Irongamer727I
                @kevin
                https://imgur.com/gallery/bGFxgyY
                • Irongamer727I
                  Irongamer727I
                  Is is this one?
                  K 1 Reply Last reply
                  • Irongamer727I Irongamer727
                    Is is this one?
                    K
                    K
                    kevin
                    Yes that’s the one. l would love to see the maths behind it,unfortunately dtpedia.de doesn’t mention it when referring to the vergaser or carburettor as we know it.
                    • Irongamer727I
                      Irongamer727I
                      @Calum is it really a restrictor?
                        @irongamer727 Not to my knowledge, the little box on the side of the air box can also be found on the competition bike WR200, they wouldn't restrict a competition bike. At least that's what @AndyYam told me. And he has a lot of experience with all of that.
                        Secondly, the PowerJet, to my knowledge (Happy to be corrected) is a clever mechanism to lean the fuel off at wide open throttle, when actually you don't need as much fuel.
                        The logic is that at WOT, you should be easing off the load of the engine and now it's all about refining that combustible mix. The leaner you can run that engine, the better the burn of combustible mix can be.
                        The trick is to lean it off as much as possible, without causing detonation.
                        • Glynn123G
                          Glynn123G
                          Glynn123
                          Removed that little airbox bottle on mine, can't say I noticed any difference but bike runs strong with pleanty pull with it removed and plugged.
                          • Glynn123G Glynn123
                            @glynn123 There are better ways to restrict the bike than some plastic box on the inlet tract lol.
                            I don't know the science behind it, I figured it would work in a similar fashion to the YEIS. But it's as mystery.
                            The DTRE also had YAIS as well.
                            • Irongamer727I
                              Irongamer727I
                              My Haynes manual says stock pilot jet fit the Dtx is 17.5? What the hell? Thought it was 25.
                                K
                                K
                                kevin
                                @irongamer727 first flatslides came with 22.5 and later models 17.5 and 210 mainjet
                                • K kevin
                                  Irongamer727I
                                  Irongamer727I
                                  @kevin Alright, thx
                                  • Irongamer727I
                                    Irongamer727I
                                    So I was finally able to unscrew my pilot jet for my dtx. It is a nightmare to start now with the Athena kit. I looked in the Haynes manual and it claimed stock pilot jet for the dtx was 17.5.
                                    Mine was a 35! What on earth? How is it possible it is hard to start NOW and not when it was 100% stock?
                                    Pilot jet size 35 https://imgur.com/gallery/fS02dV8
                                    • Irongamer727I
                                      Irongamer727I
                                      Either way, it is too big right?
                                      • Irongamer727I
                                        Irongamer727I
                                        Response please...
                                          Ask any tuner how to set up a carburettor and you'll get the same response.
                                          It depends on your setup.
                                          Everything from Atmospheric conditions to state of the engine and even altitude will affect jetting.
                                          It's imperative that ones carb is tuned to these varying conditions.
                                          20 years ago, Yamaha spent thousands on designing the perfect carburettor settings to get the DT roughly in the right ball park.
                                          The moment you started modifying the bike, you throw all of Yamaha's hard work out the window.
                                          Just because it had some ridiculous settings on it, doesn't necessarily mean it was wrong.
                                          Jetting should be done to suit, and there is reams of guides on here to help you get the bike in right area.
