  3. Welcome New Owners!
  4. New Owner
New Owner
27 Posts 8 Posters 7.1k Views 1 Watching
  • M Offline
    M Offline
    me0u01c1
    Just got a 96 from unit 5 to potter about on whilst going for my mod2.
    Went out tonight for a spin and the rear started locking up. Revs would drop and then it would squeel to a halt. Was difficult to get into neutral and start but after a few minutes it would be ok for a few minutes and then the same thing would happen again. Any ideas? Is the gear box buggered?
    Thanks
    Chris
    N 1 Reply Last reply
    • O Offline
      O Offline
      Sounds like it's seizing to me, take it back and get them to sort. Any air leaks on carb side of inlet?
      • O Offline
        O Offline
        And welcome btw!
        • M Offline
          M Offline
          me0u01c1
          wrote on last edited by me0u01c1
          Thanks oldman, was planning to take some photos and introduce it proper but issues overtook. When you say seizing what do you mean #totalnoob
          M 1 Reply Last reply
            Yeah sounds like the engines seizing to me.
            Definitely don't ride it any more.
            Time to tear down the motor for a rebuild.
            • M me0u01c1
              M Offline
              M Offline
              Minia
              @me0u01c1 Engine seizure is when your piston gets stuck to your cylinder walls. It can happen for a variety of reasons including mechanical failure, overheating (i.e cooling failure) or just rust and old age. Sounds to me like your bike is seizing a bit, the fact you can go several miles, stop and then continue going on. If you're lucky it may be an air leak or just a bad carb setup. If not, it will be at least a top-end rebuild of the engine.
              If you're a bit of a noob and not confident about putting your hands on it, then take it back to Unit 5. I assume the possibility that they have a warranty and probably don't want you to touch the bike.
              How many miles has the bike got on it?
              • M me0u01c1
                Thanks
                Chris
                @me0u01c1 Welcome to the club, sorry to hear that your having some probs already. 😞
                • M Offline
                  M Offline
                  me0u01c1
                  Bugger. The bikes done 17000km, and while there maybe a warranty of sorts i'd be on the hook for transport which would be about £300 there and back (bought online) so I shall sling it in to the local bike shop. I'm not that bothered about the cost/repair, as it sounds like a wear part anyway, it's just a PITA as I've got my MOD2 in 10 days and could do with the practice. Ah well cant be helped.
                  Is there anything else I should get them to look at? Or should I just trust the garage (North Cornwall Motorcycles) to sort it out.
                  the beast in question:
                  (https://imgur.com/83EvE8d)
                  • M me0u01c1
                    @me0u01c1 Oh that looks really nice.
                    From your description it sounds like the engine needs a freshen up, but it is hard to tell without seeing it in person.
                    Yes unfortunately on two smokes, piston and rings is just maintenance, easy enough job.
                    Obviously when they tear down the engine they will want to ensure there is no play in the connecting rod as obviously the forces exhibited during a seizure will shock all the bearings.
                    • M Offline
                      M Offline
                      me0u01c1
                      So just got back from the garage, looks like the 2 stroke pump has had it. He started it up and he felt it sounded ok so he'll start with the pump before taking the head off.
                      The only issue is that he quoted £400-500 to rebuild the top end, is that not a bit extreme for a maintenance item? We're not talking a panigale here, or am i being soft? Its approx £100 in part according to yambits so 8-10 hours labour?
                      • M me0u01c1
                        @me0u01c1 That's a lot of money. The pumps are pretty reliable and don't tend to fail
                        If the pump has failed, then you've failed to lubricate the small end bearing (fine that's included in a top end rebuild), the big end bearing and the mains bearings.
                        All of these must be inspected prior to rebuild, else your fresh top end will not last.
                        If this were me, I'd be inclined to fix it myself. It's really not that difficult.
                        If you don't want to do it, then you have to pay the price for someone else to do it.
                        In my Opinion, £500 sounds like the price of a full engine rebuild. Usually see a full rebuild at around £200 mark, but if they're removing the engine from the frame they will charge that back out.
                        The top end can be installed with the engine in the frame, and there really isn't much to go wrong.
                        I wouldn't pay £500 for a top end rebuild, for £100 you could do it yourself. £150 with forged components.
                        The rebore/hone will set you back £40. Pistons vary from £40-100 and the gaskets are £15.
                        If he's putting a brand new pump on there then the pump is £80
                        https://www.ajsutton.co.uk/genuineparts/9028/5/yamaha-dt125re-2005/oil-pump?uID=0
                        The price is the price I'm afraid.
                        • M Offline
                          M Offline
                          me0u01c1
                          @Calum cheers for the info, tbh his first gambit was 'its a winter job' and then tried to sell me another bike so...
                          Once I got it out of the van, and he had a play said he'd look at the pump (he pulled the 2 stroke feed off the engine started and nothing came out), and to call back on monday. If he can't or hasn't done owt with it I'll pick it up and have a stab.
                          It was more the rush (9 days to MOD2) but for £500 and a couple of weeks wait I might as well have a go. I've done cylinder heads on VAGs in my yoof, just old and busy (ehm lazy) at the moment.
                          • O Offline
                            O Offline
                            Agree pump failure unlikely but can be repaired to as new for around £50 quid. Sounds expensive to me, if it is a full rebuild could save money getting engine out yourself if you'rehandy with tools. Ask supplier for contribution to repair, should have been in a serviceable condition at sale.
                            • M Offline
                              M Offline
                              Minia
                              Oil pump failure? Not unheard of but uncommon for sure. That certainly explains things, I didn't even think about it. Well if it's just that I can't imagine much has gone wrong, these engines are pretty much bullet proof. I'd probably take off the head and see how things look, you might be lucky and just need to replace the pump which is an easy job.
                              • M me0u01c1
                                @me0u01c1 Pretty sure the pump utilises engine vacuum to draw the oil through as well. They also use very little oil anyhow, turning the engine on and disconnecting the oil feed may provide unrealistic diagnosis. I'm not convinced at that I'm afraid. But I work in IT, what do I know.
                                • F Offline
                                  F Offline
                                  I know from when I first fitted my clear oil lines that at idle the engine uses a minuscule amount. Even with the oil pump pulley fully rotated (maximum output) I reckon it took a good minute or two to fill the lines up to the engine. Which is what, 3 inches of 4mm hose?
                                  • F finnerz89
                                    @finnerz89 I don't think pulling the oil line off the engine is representative of "The oil Pump has failed"
                                    Sorry but I want more reasoning than that.
                                    F 1 Reply Last reply
                                      F Offline
                                      F Offline
                                      @Calum I completely agree. He didn't even check the spark plug? Could be running really lean, has he checked the cooling system?
                                      • M Offline
                                        M Offline
                                        me0u01c1
                                        Dunno tbh guys, he said he'd have a look and let me know, I'm just going to have to trust he knows his onions and not looking to be ripping me off.
                                        The other garage in town wouldn't even consider looking at it for a month so not much option. I'll speak to them on Monday and see what the gen is, if its not 'fixed' i'll bring it home and get the spanners out.
                                        And if that happens I hope you like pictures of engines and questions.... :smiling_face_with_open_mouth_smiling_eyes:
                                        • M me0u01c1
                                          @me0u01c1 To be honest, we're all here any how and are happuy to lend a helping hand. There may be a member on here nearby willing to give you a happy end.
