  3. DTX
  4. Dt125x bleed brakes
Dt125x bleed brakes
front brakes
11 Posts 6 Posters 3.2k Views
  • 0 Offline
    0 Offline
    02sahe
    I have swapped out the old brake pump with a new one, i have tried to bleed it, but it dosent work 😞
    Any tips?
    • M Offline
      M Offline
      Minia
      Does it feel right to you? Have you checked your calipers? pistons?
      0 1 Reply Last reply
        What you swapped out? The master cylinder. Does it definitely work?
        I've had issues in the past, on my RS master cylinders that simply would not bleed.
        CalumC 0 2 Replies Last reply
          @Calum New Calipers and/or master cylinder was literally the only way to get them working. Bled straight away after that.
          • M Minia
            0 Offline
            0 Offline
            02sahe
            @Minia yes i habe cheked, and its all good. Just swapped out the master cylinder.
            Then i tryed to bleed it, and it dose not work
              0 Offline
              0 Offline
              02sahe
              @Calum i had a ebay mastee cylinder i think. I changed it to an original, now i cant get any pressure..
              N 1 Reply Last reply
              • 0 02sahe
                @02sahe Get yourself one of these dude, it will bleed your brakes superbly!!!
                https://www.ebay.co.uk/itm/TBS-One-Man-Motorcycle-Bike-Brake-Bleeding-Kit-NOW-WITH-DOT-FLUID-A/112152432569?hash=item1a1cce4fb9:g:gOIAAOSwynRZvqgE
                  I highly recommend this.
                  https://www.ebay.co.uk/itm/HAND-VACUUM-PUMP-HELD-BRAKE-BLEEDER-TESTER-SET-BLEED-CAR-MOTORBIKE-BLEEDING-KIT/391718817400?epid=9026714704&hash=item5b3442ce78:g:c48AAOSwB-1YuE1W&frcectupt=true
                  I've used it and it works wonders. Very cheap and Chinesy, don't expect it to last every day. But I've done countless cars/bikes with it. Great cheapy kit that works. Much safer than pumping the brake.
                    @Calum You know I just saw those kits, which must be fairly new? And was going to suggest one, but as I have not used one myself, I decided to go with the syringe kit instead. As I have used that kit and know that those kits work very well too.
                    • B Offline
                      B Offline
                      britshgigolo
                      i find with the dt they can be a pain and the vacume kit works wonder especialy if replacing hoses and master cylinder
                      • F Offline
                        F Offline
                        +1 on the vacuum kits.
                        I've only just got one and now I'm wondering how I got on for so long without one lol
