  3. Framework
  4. Help Removing Swinging Arm Linkage :))
8 Posts 5 Posters 2.2k Views
  • jakeyboyJ Offline
    jakeyboyJ Offline
    jakeyboy
    Anyone got an idea how to remove this bolt? Can’t remove the linkage...
    • MightymanM Offline
      MightymanM Offline
      Pictures fixed 👍
      Could be completely wrong but it looks to me like it might push out rather than unscrew, but could be rust seized so will require a lot of force.
      I've never actually removed the linkage on one of these bikes so I wouldn't start hammering until someone else can confirm though 😅
      • F Offline
        F Offline
        Should push out from the other side. I had this problem and in the end resorted to cutting it out and buying a used relay arm.
        The bearings were rusted solid on mine
        • jakeyboyJ Offline
          jakeyboyJ Offline
          jakeyboy
          Would applying heat be a good or bad idea??
          M 1 Reply Last reply
          • jakeyboyJ jakeyboy
            M Offline
            M Offline
            mhbikesnbits
            @jakeyboy good idea apply heat penetration fluid and a good hit with a drift
            • Walney-ReptilesW Offline
              Walney-Reptiles
              This is the next thing to remove on my list will let you know how i did it if i manage to get it off
              • F Offline
                F Offline
                The main issue is getting at it to drift it out. The frame rail is in the way unfortunately
                • jakeyboyJ Offline
                  jakeyboyJ Offline
                  jakeyboy
                  Cheers gents, with a lot of heat and a massive hammer got it out :)
