  4. DT125X cooling problem
coolingproblemcoolant
14 Posts 6 Posters 2.7k Views
  • S
    SouthWalesYammy
    Hi everyone,
    Right so I’ve done a top end rebuild of the engine and the engine runs sweet. Running it in as I go to make sure it works properly.
    However, I’ve come into a problem.
    The coolant system keeps emptying itself. It first started with a bit of a leak from the top of the radiator near the cap, but then the majority of it ended over the rear tyre so seemed like it was something to do with the overflow/expansion.
    I replaced both the thermostat and radiator cap, then refilled with coolant. This seemed to fix the problem but then found the system to have let a load out again over the rear of the bike (no longer any from the radiator cap).
    My thinking is it is something to do with the expansion/overflow bottle. Any ideas?
    Also, I was using a putoline coolant, any other recommendations?
    Thanks in advance
    • O
      O
      Head gasket leak
      • shellatitS
        shellatitS
        shellatit
        If you have used genuine gaskets and it still does it I would say the head is possibly warped
        • O oldman
          Head gasket leak
          SouthWalesYammy
          @oldman said in DT125X cooling problem:
          Head gasket leak
          Would this cause the coolant to end up over the rear tyre, it’s right below where the overflow bottle is. That’s what makes me think it’s that
          • O
            O
            Yes. System overpressurises with combustion gases forcing fluid to escape to expansion tank
            Did tank have liquid level prior to problem? Would overflow with excess coolant
            • O oldman
              SouthWalesYammy
              @oldman
              Ahh okay, do you think I’d be better off checking some other things first (the hoses attached to the expansion bottle, the diaphragm and cap) before taking the head off?
              D 1 Reply Last reply
              • S SouthWalesYammy
                @oldman
                DTR+NSR
                @SouthWalesYammy is the area where the rad cap seals agains't sound? I had exactly same symtoms and in end traced it to corosion damage where the rad cap seal, seals against.
                • D DTR+NSR
                  SouthWalesYammy
                  @DTR-NSR
                  Are you talking about on the inside of the opening on the radiator? Or on the estimator cap itself?
                  • S SouthWalesYammy
                    @DTR-NSR
                    DTR+NSR
                    @SouthWalesYammy inside the opening on the radiator. There's a slight raised ridge the rubber seal on the rad cap seals agains't. If the system can't pressurise there, the coolant will expand as it warms and flow straight to the over flow bottle.
                    • O
                      O
                      Considering you have just done a top end rebuild and the problem started my money's on the head gasket. Easy to sort a warped head (if that's what it is) there's a tutorial on here somewhere. Or did you use a cheap gasket?
                      • D DTR+NSR
                        SouthWalesYammy
                        @DTR-NSR
                        I’ll check this Saturday when I get out to look at the bike, thank you!
                        • O oldman
                          SouthWalesYammy
                          @oldman
                          Hopefully it’s not this, I’m going to check everything else first then this’ll be my last call😬
                          • Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            Id also go with the head gasket, happened many times with me until i skimmed my head with a glass mirror and wet n dry sand paper
                            • S SouthWalesYammy
                              @oldman
                              @SouthWalesYammy I had the same problem mine fixed it’s self) EDIT) the only thing to do with cooling i changed was the radiator cap maybe that was the issue?
