  3. Suspension
  4. Front fork bearings 1992 dtr
12 Posts 4 Posters 2.1k Views
  • J Offline
    J Offline
    jonne123
    What size are the bearing balls how many of them? Does the fork have bearings under too or just the top?
    427f3151-067e-4f99-82a9-998c7bbca5ac-image.png https://ypec-sss.yamaha-motor.co.jp/ypec/illust/3/3MB1300-9240.PNG
    • J jonne123
      @jonne123 They aren't individual balls. They are tied together in a race. So you don't order individual balls of steel.
      Just measure the race and the stem and order them from anywhere.
      Yes, Part 1 is the bottom bearing again, just measure it and order it.
      I'd recommend SimplyBearings for quality bearings at a great price.
      • J Offline
        J Offline
        jonne123
        How much is the race?
          Comes with the bearing.
          • J Offline
            J Offline
            jonne123
            So?
            1 bearing for bottom
            1 bearing assembly for top
            • J jonne123
              So?
              @jonne123 Yes that's correct.
                Louis-DT-WRL Offline
                Louis-DT-WR
                Pretty sure I put a tapered set in mine, might be worth upgrading.
                • J Offline
                  J Offline
                  jonne123
                  i have needle bearing on bottom
                  • J jonne123
                    @jonne123 yeah we all do the upgrade means you have one on top
                    • J Offline
                      J Offline
                      jonne123
                      how do i do that?
                        I mean what do you gain from doing this?
                        • J jonne123
                          how do i do that?
                          @jonne123 I wouldn't bother tbh
