  4. So Close!...
So Close!...
1.1k Posts 26 Posters 642.1k Views
  • HOTSHOT IIIH HOTSHOT III
    @MH-Bikes-N-Bits using a 1/4" drive torque wrench (£20-£30 from a cycle shop) and 1/4" drive universal joint and 12mm socket you can get to all the head nuts with the engine in situ, even the one at the front which is close to the frame.
    Alternatively you can remove all the engine mount bolts apart from the swingarm pivot and rotate the whole engine around it a few degrees to improve access (I did this once to replace the O-ring in the steel water pipe without disturbing the waterpump cover as I had reason to believe one of the cover bolts was seized)
    @SpookDog At this rate, I'd almost say get the head machined with an O-Ring and run that as a gasket as this is getting seriously ridiculous now.
      #202
      That’s been circling around my noggin for a while. There was a thread about someone getting it done at PJME but I never saw any follow up. Interested in knowing the price. I’ve got a 4fu barrel I wouldn’t mind getting sleeved by them as well...
      @ mikes bits
      I did remember someone saying about re-torquing the head 🙂 Is it after it’s been run to temp then cooled down? I wouldn’t do it while hot!...
      @ hotshot
      I’ve never done it before, but the nuts were not super tight, so it got me wondering...
      I remove the bottom and front mount bolts, loosen the swing arm bolt and lift the front of the engine with a big screwdriver. Once you’ve taken off the thermostat cover you can get in there nicely with a 1/4 drive torque wrench 😜
        One thing that I’ve never done is re~torque the head after riding the bike up to temp. I’ve just put a ring spanner on the head nuts and given them a tweak. It was surprisingly easy to tighten them (Very surprisingly easy!!) Looking back it was never hard to undo them when tearing down the top end. I haven’t seen anything about re~torquing in the Haynes. Only ever seen it recommended with car head gaskets that are those silver multi layered ‘compressible’ stuff...
        Does everyone else retorque after running up to temp?...
        MadGyverM
        MadGyverM
        MadGyver
        After about little run in on the first km's I check every bolt and re-torque the head and cylinder.Almost every time was ok,one time one headbolt need it a little more but nothing serious.
        • MadGyverM MadGyver
          @MadGyver
          Cheers geez, it’s all good to know. I didn’t think it was absolutely necessary, but there you go. No two situations are exactly the same...
          @anyone
          I’ve gotten myself a new piece of plate glass (6mm was thickest I can get locally) and loads of fresh w&d from 80grit on through to 600. I’m gonna have one last go and give the head (especially) and barrel a good lapping. If it fails after this I’m gonna get a good 3mb head cnc grooved for orings (is it one or two on a standard head? I still want to know why it’s good for about a 1000 miles before it fails. I would imagine it’d fail sooner if it was poor finishing of the mating surfaces? But, hey ho! One problem at a time! I will get both surfaces skimmed if I can find a good local engineer that hasn’t lost practice cause of Covid 😟
          I still want to build another bottom end when I can afford genuine seals and bearings all through. I’ll never buy non genuine fleabay again, that’s for sure. I prefer my Crap Shoots to happen in a Casino! 😜 ...
          Good luck to the people’s with problems, love to all else! ☠️🐾
            @MadGyver
            @anyone
            #205
            @SpookDog
            Just took of the head and the gasket failed at the back of the head, passing pressure to the big coolant opening on the gasket (the others are just 4mm holes) at the mounting point. It’s failed there a few times. I don’t have an original bolt at the front engine mount point, just an Allen bolt. I’m wondering if it’s putting stress on the head mount. Or if it’s just the easy/biggest target?...
              @SpookDog
              #206
              @SpookDog
              Whacked on another Vertex I had laying about. It was a reject to start cause of very slight creasing, but beggars are not the choosiest!
              I did give the barrel a good clean/lap. The head I gave extra attention with 150 grit...
              Did a 70 mile run in test, nothing over 6k rpm. Temp right on the 60degC thermostat ‘just opening’ spot on the temp gauge. During the hot weather it was up on the 80degC ‘wide open’ spot. It was like trying to cool the radiator with a hairdryer!!...
                @SpookDog
                @SpookDog
                Another 70 mile trip with no problems...
                  @SpookDog
                  10 days and about 700 miles later the radiator level is starting to drop, expansion tank over spilling. This is like fucking clockwork. I just can’t get my head around it!
                  I’m going to have to get a head professionally skimmed, as well as a barrel...
                  I also need to find out how much someone like PJME charge for an o~ring conversion...
                  I’ve only recently found out that you can still get Yamaha DTR125 genuine head gaskets!? I read somewhere that they are thick ‘rubber coated’? I just assumed that they had the same thin black coating that Vertex or Athena head gaskets have and you payed a premium for the Yamaha name? Has anyone seen/used a £40 genuine gasket and can give comparison with Athena or Vertex, similar, gaskets?...
                  It would be a big help 🙂 ...
                  markus.wM MadGyverM 2 Replies Last reply
                    markus.wM
                    markus.wM
                    @SpookDog for some reason I thought you knew to use original or Athena. Can't comment on vertex but I've always been of the belief that only genuine or Athena will do.
                      MadGyverM
                      MadGyverM
                      MadGyver
                      Have you used custom copper gasket with copper gasket spray,they used it for high compression and performance engines,you can anneal the gasket to become softer and sit even better.
                      You probably burn slowly coolant and venting pressure in the cooling system.
                      I only use yamaha or custom copper head gaskets+copper spray.
                      • Stevie WonderS
                        Stevie WonderS
                        Stevie Wonder
                        I’ve got a copper gasket in my room being used as an ornament. Pay for the postage and buy yourself the magic spray and it’s yours
                          #212
                          @Stevie-Wonder
                          Email me your address and I’ll post you a stamped addressed suitable envelope 👍
                          boonierat13@gmail.com
                          I just brought a can of Permatex spray on copper sealant. ...
                          @ Madgyver
                          Are the Yamaha ones coated really thick with rubber like stuff?...
                          Didn’t have any luck with the last one I tried. Mainly cause I muffed up the annealing as well as using sealant from a tube...
                          Cheers Guys...
                          S MadGyverM 2 Replies Last reply
                            @Stevie-Wonder
                            @ Madgyver
                            Cheers Guys...
                            #213
                            Anyone had any experience with ‘exhaust banging’ or engine knocking at low rev coasting? The best description I’ve read of it is that it sounds like someone hitting your engine with a ball peen hammer sharply. It’s basically misfires which happens to be one of the biggest head gasket killers...
                            interesting reading!
                              Curve ball question: anybody tried fitting a TZR pipe to a DTR125?
                                @Stevie-Wonder
                                @ Madgyver
                                Cheers Guys...
                                MadGyverM
                                MadGyverM
                                MadGyver
                                @SpookDog
                                Permatex copper gasket spray is what I use,great product.
                                Yamaha ones are thin coated.
                                  @SpookDog
                                  @MadGyver
                                  Ah!!.... So simular to Athena, ect? Not wildly different? Cheers bud, I really need to know this stuff. I can always trial & error it but at £45-50 for a genuine gasket I’d rather be told! 😜👍 I am not a wealthy person, only job I have is getting out of bed in the afternoon...
                                    HOTSHOT IIIH
                                    HOTSHOT IIIH
                                    @SpookDog I guess you could make a TZR pipe fit but is there a reason you want to?
                                    Also the TZR (2RK) engine is very different to the DTR; much lower compression (I can remember blagging a go on a mate's TZR and thinking it'd blown up when I kicked it over) and the CDI unit is different as well as a few other bits.
                                    Not wishing to shoot down your idea, a lot of lads in Portugal build DTRs with underslung pipes, I'm just curious
                                    S CalumC 2 Replies Last reply
                                      #218
                                      @HOTSHOT-III
                                      Not for any long term reason. My ‘big one’ is falling apart. I’m looking for reasons that would cause poor scavenging of exhaust gasses (Ive been getting bad knocking/misfires for a while when coasting @ low throttle) I really just want to substitute another pipe for testing. I have a 94 TZR pipe laying around...
                                      On a simular subject I just checked my reed valve and it is not fully closing (on 1 side petal) when ‘relaxed’ out of the bike. I don’t know much about them other than they are a one way valve, not sure if they should be sprung closed, or forced closed by the piston pressure when it goes down, or both!...
                                      If it’s not holding the mixture in the crank case it could maybe really fuck it up and cause misfires, which in turn murder head gaskets...
                                      I wish I was a bit smarter! 🤪
                                        @HOTSHOT-III I run underslung, wheelie machine 🤣 🤣
                                          @HOTSHOT-III
                                          #220
                                          Hmmmm?! I just checked the Haynes manual and found out the ‘stopper height’ for the reed valve on the DTR125 is supposed to be 6.8mm, TZR 8.3. Mine is 11mm! I might just of found at least part of the cause of my ‘pipe banging’ which in turn could be the cause of my gasket problem...
