  4. So Close!...
So Close!...
1.1k Posts 26 Posters 758.7k Views
    @HOTSHOT-III
    Parlez vous froglish? If I give you my VIN would you do it for me? 😬
    HOTSHOT IIIH
    HOTSHOT IIIH
    @HOTSHOT-III
    OK what's your VIN number?
    • HOTSHOT IIIH HOTSHOT III
      @HOTSHOT-III
      #442
      @HOTSHOT-III
      Thank you!
      X 3DB 3001369 X
      markus.wM 1 Reply Last reply
        @HOTSHOT-III
        Thank you!
        X 3DB 3001369 X
        markus.wM
        markus.wM
        @SpookDog is that the early round slide carb model? Quite a rare model if it is.
        • markus.wM markus.w
          HOTSHOT IIIH
          HOTSHOT IIIH
          @markus-w @SpookDog It should be a round slide carb bike with that VIN number. I had a look on Yamaha France but it didn't recognise the VIN so just looked it up as an '88 DT125R; the original part number is 1W2-25190-00 and CMSNL/Fowlers both say it's superseded to 3XP-25190-00. The 3XP looks like the plastic version on CMSNL, in stock at Fowlers, £74.40:
          https://www.cmsnl.com/products/gear-unit-assy_3xp2519000/
          https://www.fowlersparts.co.uk/parts/4055682/dt125r-3bn1-1988-999-c/front-wheel
          Maybe try Motorcycle Part Finder UK, they contact over 200 breakers:
          http://partfinderuk.co.uk/
            It’s not a righteous numbers matching bike, it was mongrel from the time I got it. It had a late model flatslide on it when I got it…
            The X’s are the weird Yamaha star things, not part of. It worries me that it wasn’t recognised though…
              #446
              In the daylight it looks like
              3DB - 001369
              With a big gap between the 3DB and the 00
              It says there are 3 options: black, white & solid enduro blue. I’d love to know what original colour my bike was registered as, can anyone help me find out?…
                @HOTSHOT-III
                What do you recon bud?…
                114454049955
                EBay…
                  @HOTSHOT-III
                  114454049955
                  EBay…
                  HOTSHOT IIIH
                  HOTSHOT IIIH
                  #448
                  @SpookDog That's for an SR125 which has I think an 17" front wheel, and the spindle diameter is likely to be different as well so it definitely wouldn't fit a DTR.
                  https://www.motorcyclespecs.co.za/model/yamaha/yamaha_sr125 97.htm
                  Have you tried Motorcycle PartFinderUK from my previous post?
                    #449
                    @HOTSHOT-III
                    Same diameter 15mm. I was more interested in the 3 prong internals. I could use my gear wheel if not my worm drive. There are some used ones going for £11 I’m going to see if I can find measurements for one. The 3 prefix letters are different but the middle numbers (25190) are the same, it has an 01 on the end instead of a 00. I’m hoping that an upgrade to where the cable fits in, an oring maybe 🙂 I live in hope!…
                    Gonna try part finder later today but don’t think it’ll be cheap…
                    Edit Got one coming for £8 it’s worth laying eyes on for that price…
                    There are mid 80’s XT ones that look the same, 3 prong and seal ect. Some of the XT’s used the same speedo/rev counter as the dtr I think…
                      @HOTSHOT-III
                      Would you believe it that my top end has developed a rattle that is only getting worse! 😬
                      It’s my fault for using second hand top ends before, because I couldn’t cure the head gasket blowing problem.
                      Now I’ve solved it I want to get my original 3MB barrel rebored with piston, ect. I’ve got another bottom end I want to put new everything in as well though, while I’m at it.
                      I might put the Tzr on the road first though. So I’ve got something to run while I get the frame and casings, ect powder coated…
                      Juggling decisions on a shoestring budget, you kinda got to get it right before you do it 😐
                        #451
                        Can you believe that this worm gear will still not just pull out?! 😵‍💫 …
                        Even after beating the brass cap/insert up & out the worm gear shaft won’t come out 🙂
                        I had to cut down even further because the hard steel of the worm gear had ‘burred’ over a lip on the ally that held it in!…
                        And finally! Freedom! And it’s not bent!…
                        My~Fucking~Life!…
                        SAPFM!….
                        @HOTSHOT-III
                        Is there supposed to be a washer on the top @ bottom of the worm drive?
                        Mine only has one on the top? I’m guessing that the spin makes the drive ride up against the top washer, so it doesn’t need one on the bottom?…
                          My~Fucking~Life!…
                          SAPFM!….
                          @HOTSHOT-III
                          HOTSHOT IIIH
                          HOTSHOT IIIH
                          @SpookDog I noticed the washer was always on the top of the worm drive when repairing the plastic ones; odd because as the worm gear rotates with the wheel, IMO it pushes the worm drive downwards. As I said I bought a load of shims the correct ID/OD for pence from China and just shimmed mine at top and bottom when reassembling.
                          I wouldn't go for the SR125 NOS one if I were you; if the spindle is the same diameter all well and good on that score but the internal gear ratio will be completely different for a 17" wheel meaning the speedo won't read correctly. And paying £55 to try and swap your internals into it, you might as well pay the extra £19 for a brand new 3XP one from Fowlers.
                          Expensive for a speedo drive though yes, I'd be getting on to PartFinder and Googling breakers all over the UK. Also consider getting on FaceBook as there's around 15-20 dedicated DTR pages full of helpful people, some of whom buy and sell DTR parts all the time. This forum is excellent but bottom line there's more people on FB, I'm not a huge fan of social media but you have to make it work for you.
                          IIRC Yamaha use the same numbering system for all their parts, the actual 5-digit number is the same for a particular item (a spoke set for instance) and the 3-digit prefix denotes the model (3XP = DT200WR I think, so I guess they adapted that bike's USD forks so th same shape speedo drive could be used). 00, 01, 02 etc. endings are where a part has been superseded with minor changes.
                            #453
                            @HOTSHOT-III
                            I’ve ordered a second hand one for £8.00 I don’t think I can go wrong at that price…
                            Damn it I’ve got water in the carb again! I think it’s cause my tank is very rusty inside which massively increases surface area, add that to a cheap cap that lets air in and it gets a lot of condisation in the tank. It’s the only reason I can think of anyway. Just another upgrade job to do when I have the money and off road time to do it. Or stop running it onto reserve! 😛 Looks like I’m going to have to get the Tzr running, which I’m going to have to half ass to start cause I don’t have the money to get the 4Fu steel liner put in @ PJME…
                            Happy daze to all you smokers out there! 😬 I hope you have better luck with them than I does…
                              @HOTSHOT-III
                              #454
                              Stripped and cleaned the carb last night and put it back together, then the 250 main jet I ordered a while ago turned up this morning! 🙂 …
                              Bikes running well again though without the blob of water molesting the jet…
                              Noticed that a couple of the links on my x-ring chain have locked solid. The road salt really kills them in no time at all. Thankfully spring is real close and I have new chain and sprocket, along with new tyres to go on. Will have to put the new forks together without painting them like I wanted. Those are the licks of being a peasant tho! 😀 …
                                #455
                                @SpookDog
                                Just another Monday night 🙂 …
                                Took the top end off to change the little end bearing. Turns out it was the gudgeon/wrist-pin had eaten away at the piston and allowed enough slack to vibrate like… well, a vibrator 🙂 but on one side only…
                                I’m guessing it was caused by yet another piston ring placement pin failing? Basically the top ring was free to spin/turn as and when/where it pleased. Judging by the wear on the ends of the top ring it looks like it was playing chicken with the inlet (& exhaust!) ports 😛
                                Both ends are chamfered off! Also my power valve looks like the loose rings were polishing it!
                                I’ll get there eventually though, I’m nothing if not stubborn 😬 …
                                  @SpookDog
                                  Nothing has touched this outside of the barrel…
                                  It’s polished and chamfered by the top ring I’m guessing…
                                  I think I’m real lucky that this didn’t snag a port & detonate, so i guess things could be worse 😛 …
                                    @SpookDog Dayum! Luckily these engines are so simple it's just a case of dusting it off and reassembling.
                                    I took delivery of new piston/rings/gaskets/small end this morning, so I'll be fitting my ported big bore soon!
                                      Yep, I couldn’t get a decent pic of it but the top ring location pin has just ‘disappeared’ off flush with the piston. Weird having two fail in a row so soon. The top ring was literally spinning around in the groove. I’m amazed that an end didn’t tangle with a transfer port…
                                        @HOTSHOT-III
                                        markus.wM
                                        markus.wM
                                        @SpookDog there's a Speedo drive on Facebook group for £40 Inc postage.
                                          HOTSHOT IIIH
                                          HOTSHOT IIIH
                                          @SpookDog The genuine Yamaha pistons have always been prone to ring pegs getting out and walking on the DTR, TZR125 and TZR/TDR250. Back in the 90s when having a rebore, we would demand Japanese Mitaka piston kits by name as they were better. Not tried any of the Wossner etc. ones available these days but Mitaka always did the job for me and I think PJME sell a lot of them.
