  4. So Close!...
So Close!...
1.1k Posts 26 Posters 665.3k Views
  • markus.wM markus.w
    @SpookDog I've always used Texaco super unleaded. Lots of Texaco stations near me, I never use super market fuel. Premium is 10% ethanol and super is 5% but even long before the change of ethanol I used it as it's a better quality cleaner fuel and what you lose on the 10p per litre extra cost you gain back on the extra miles per litre/gallon.
    Does anyone have an idea on how much it costs to get a wheel rebuilt/respoked? Just the labour? Has anyone had any done?…
      HOTSHOT IIIH
      HOTSHOT IIIH
      @SpookDog Contact Mike at Salisbury Wheel Builders (now in Ringwood) on 07967 548015. Very good reputation locally, does everything from modern MX bikes to 100-year-old Brough Superiors, can make new spokes and supply new rims, everything
      • HOTSHOT IIIH HOTSHOT III
        @HOTSHOT-III
        Cheers buddy…
          @HOTSHOT-III
          Cheers buddy…
          #484
          I’m having some real problems removing the base barrel studs from the right hand clutch side casing of an engine I’m getting together for building. The flywheel side studs came out easy enough with heat and 2 nuts cinched onto it.
          I don’t know if the locator dowel tubes are making it more difficult to get heat into them but they just won’t budge no matter how much heat I apply. The main crank bearing actually fell out while I was trying!! I’ve been putting WD40 into the dowel tubes before and after heating and trying to remove the studs, but no luck yet. If anyone knows of any arcane methods of extraction please let me know 👍 …
            @SpookDog Yeah I had a VERY similar issue when doing my crankcase studs. I just applied ridiculous amounts of heat. I may have used an impact gun?
            I guess what I am saying is, been there also!
              #486
              I hear you! I’ll just have to keep on being my stubborn old self ☠️ I might try putting it in the oven @ 200+C
              I worry about distorting the casing, or destroying it’s molecular structure/integrity though. I’m a worrier if you haven’t guessed 😵‍💫 …
              On a brighter note, the YBR fuel tap is a direct fit. The only problem is the YBR has a plastic round ‘lever’ that doesn’t look right. A DTR one will fit, but needs modifying at the back to allow an extra outlet to the filter bowl, and I don’t have a spare to use at the moment. The YBR tap has a wicked little filter inside the catch bowl! I’ll take some pics soon as, cause words alone can’t explain what I’m trying to say…
                @SpookDog yeah oven should be fine. I put my cases in 200 degrees when I fit bearings.
                  HOTSHOT IIIH
                  HOTSHOT IIIH
                  @SpookDog Clutch side cylinder studs: If you can get the locator dowels out first, that will expose all the rust/corrosion lurking between the stud and the dowel which you can then remove somehow without damaging the surrounding gasket face (wire brush/sharp thin things etc.); this will give the penetrating fluid a better shot at the actual stud/crankcase interface.
                  I had a set of 90 degree squares from Lidl and the handles were extruded aluminium; inside there was a round hole roughly the same size as the dowel OD running right along the handle. So I cut a 20mm or so section off the end, then made a hacksaw cut along the length of the hole so it could be opened out a little. Fitted it over the dowel with a little valve grinding paste for grip, then clamped it with mole grips on the ally so it gripped right around the circumference of the dowel without crushing it. Still took some persuasion/heat to remove the dowels and I replaced them with new but it got them out clean.
                    Fair play guys, I practiced on an old casing and got both out by heating inside the casing where the oil seal retainer screws in. So the heat went into where the thread was, not just the dowels. Got both out the old casing, got one out of the ‘good’ casing then the last one snapped off deep inside. I kinda lost it with a lump hammer after that 🙂 …
                    Anyone got a decent right hand casing that they don’t want? 😛 …
                      markus.wM
                      markus.wM
                      @HOTSHOT-III brough superior SS100 is my dream bike. T E. Lawrence of Arabia comes to mind.
                        They are magnificent looking bikes, no? There was one on display in a bike shop in Gillingham Dorst a few years ago. I’d never seen one before…
                        I got another casing for £20 coming soon. Round 2! 🔔 🔔 🙂
                          #492
                          Electrolysis?
                          Has anyone ever done this to remove rust from inside of a petrol tank?…
                          Here’s the ybr tap with an adorable little filter that is absolutely top drawer quality, internal o~ring seal and all!
                          It’s a same fit as a dtr or Tzr (shown) tap. The cool thing is that it’s effective as a water trap as well as being a wicked little filter!…
                          You can fit a proper looking tap ‘handle’ to it as well. It will need a bit of surgery with a Dremel or such on the rear of the‘handle’ though. you can see the difference below:
                          I know it’s not for everyone, but it’s a wicked little filter upgrade and watertrap, if nothing else…
                          R HOTSHOT IIIH 3 Replies Last reply
                            Electrolysis?
                            R
                            R
                            rollzy101
                            @SpookDog highly recommend electrolysis on your tank, the final rinse i used harpic toilet cleaner and it brought my 89 tank up like new!
                            Owned: Yamaha DT125LC, XT125, DT125R, YZF R125, CBR125, RS125
                              Electrolysis?
                              HOTSHOT IIIH
                              HOTSHOT IIIH
                              @SpookDog That is a nice tap, guess it has that filter to stop any foreign objects entering the YBR's fuel injection system
                                #495
                                Cheers guy’s! Another question: barrel dowels? Mainly where to purchase them & how much. I could probably make some but would rather use the proper ones. If they don’t fall out I seem to be destined to destroy them 😐 …
                                PS Gotten hold of a pair of rear indicators from a SR125 with the elusive mounting brackets. They look identical to the ones fitted to early Dtr125’s. I won’t know if they are the same PNs’ till I lay hands on them but they were £15 for the pair 🙂 …
                                  HOTSHOT IIIH
                                  HOTSHOT IIIH
                                  Genuine from Fowlers, get some new cylinder studs/nuts at the same time, some fasteners are worth buying genuine and they're not expensive
                                    Electrolysis?
                                    R
                                    R
                                    rollzy101
                                    @SpookDog ![s-l1600 (9).jpg](Image dimensions are too big)
                                      I ended up getting some titanium ones when I built my engine. I replaced all the engine bolts with Titanium and when all the bots are done you do shave off a good amount of weight.
                                      The front engine mount can also be replaced with titanium, the chap had it listed as a Honda Grom engine mount bolt but also fits DTR.
                                      I just bought the engine mount brackets in Titanium as well.
                                        markus.wM
                                        markus.wM
                                        @HOTSHOT-III certainly makes sense.
                                          @HOTSHOT-III
                                          I’d rather reuse the old ones than use non genuine ones!. I had some shiny ones come with a barrel I brought and they were shite. I sheared one off and it’d only been in a month or two!…
