  4. So Close!...
So Close!...
1.1k Posts 26 Posters 665.6k Views
    #meormyschizophrenicshadow
    Is it just me Callum, or has the format of the site changed again?
    @SpookDog
    Me no likely!
    Has anyone ever thought of machining an old front disc so as to ‘accept’ a larger floating disc? Seeing as there are no over the counter options?…
      @SpookDog What do you mean again?
      It's only changed the once in the entire time I've hosted it.
      I bumped the software from 2.X.X to 3.X.X (it's been on 2.X.X for many years).
      Along with the software bump I have swapped out the theme, this seemed a bit more mobile friendly.
      • S
        Yeah. To you, I’ve seen more changes as my ‘platform’ became unsupported and buttons and options like the for sale stuff disappeared. It’s just good to know it’s on your end, not mine. Serious 🃏
          Yeah, ideally you'd clear your computers cache settings as it does try to be clever and preserve the last theme from a specific software version. This causes problems where by the code has changed, but your browser has cached certain parts of the website, resulting in a conflict of information. It should fix itself when the cache expires.
          The main thing is we've moved to Bootstrap 5 now.
          • HOTSHOT IIIH
            HOTSHOT IIIH
            @Calum , since the format changed I've not been receiving notifications about unread posts/reactions to replies etc. Is there something I can change on my PC to sort this? Still running Windows 7 so as you can imagine I'm sat here jumping on my stove pipe hat like an irate Victorian railway engineer.
            • HOTSHOT IIIH HOTSHOT III
              @HOTSHOT-III So long as you are using a modern browser and not Internet Explorer you should be fine. Try clearing the browsers cache.
                HOTSHOT IIIH
                HOTSHOT IIIH
                @Calum It's working now, very strange as I've been keeping an eye on it since my TSE250 engine thread the other day. Maybe it just took your reply this morning for my software to recognise it. Anyway thanks for responding 👍
                • S
                  #528
                  Any of you arcane knowledged fuxors out there know where to get hold of the kind of seals needed to rebuild a rear shock? I know that they are specialised & not ‘mainstream’, but I know they are made and available to people (especially in the business) if you know where to look. Anyone know where to look?…
                  Ta!…
                  PS can anybod tell me what the process is called where you cut metal with a water jet? Or even the plasma (maybe?) technique? I’d like to find out about cutting sheet stainless or high carbon steel sheet …
                  • S
                    Got a bargain £32.50 crank from fleabay! It looks like it’s been cleaned (acid) before having a new conrod fitted! I’ve never seen a crank with so little play, even side to side 🙂 have everything new now apart from the clutch actuator bearing, which I’m going to fit a good used one to unless anyone knows the size?…
                    PS how to load pics? I have no button or options…
                      You just do the same as you always do, but by default the "advanced" editor is hidden. But it's just Markdown so you just write it inline
                      ![](http://example.com/example.png)
                      Markdown Cheat Sheet
                        Cheers bud!
                        WTF? It’s in the top banner above the ‘typing area’ now! 😛 I must of been using the quick post option…
                          Cheers bud!
                          Just try to buy a set of early matching casings for the engine build. The serial number is some zeros that end in 654. So I’m guessing that they’re quite early!
                          Wish me luck!!
                            Crank looks good bud, what's the crank float on it?
                            Are the threads intact?
                            Do you know what rod has been used?
                            • S
                              #534
                              Rod has 2rh on it like a standard one (?)…
                              Threads are good, there’s just a bit of a ‘knurled’ over end on the inside of the hollow bit on the stator side. Someone hammered on it (a bit) in the past…
                              It doesn’t float, it sank when I put it in a bucket of water 🙂 …
                              Sorry! It’s virtually nothing. I’ll measure it later when I’m sober 🥴 but it’s tight…
                              I noticed the two heat spots on the topside of where the centre pin is and thought it had work done on it. I don’t know whether they heat the sides to split the crank or assemble it, I’m guessing they split it. The spots look well defined so I thought it was someone who knew what they were doing. Hopefully! 😵‍💫 …
                              But seriously it looks good. About time I had some good luck ☠️
                                Managed to get the early casings for £45! Engine number 654! Sweet!…
                                Also managed to remove & measure the clutch actuator arm bearing and get a couple ordered. Gaskets are in the post. I’ve got just about everything I need to build…
                                Just need to strip a rear shock so I can measure the size of the various seals needed to rebuild one…
                                Happy daze! 🤩 …
                                  Happy daze! 🤩 …
                                  Has anyone ever used one of those steam cleaner gizmos to try and clean engine/bike parts? I’m gonna try it out and see what occurs 😎 …
                                    I use aluminium oxide shot blasting cabinet that works a treat on small aluminium parts, if you have the patience...
                                    Otherwise I send things like engine cases off to be vapor blasted.
                                      You can buy small home blast cabinets? I’ve never thought to look. Do you need a separate compressor?…
                                        Happy daze! 🤩 …
                                        HOTSHOT IIIH
                                        HOTSHOT IIIH
                                        @SpookDog I don't think the stock DTR shock is rebuildable. It's of the IFP type meaning it has an internal floating piston and the chamber behind it (right at the top of the shock body) is charged with air or nitrogen at 300+psi. Yamaha even show you exactly where to drill a 3mm hole to safely release the gas pressure before throwing it away. With those kinds of pressures it would be quite dangerous to try taking it apart IMO.
                                        It's like this so as the shock compresses and the piston rod occupies more volume inside the damper body, the IFP moves so the overall volume of the damper doesn't change and it just compresses the nitrogen chamber. This prevents the oil from becoming aerated which would result in inconsistent and/or total loss of damping.
                                        I just found this which shows how the IFP works, ignore the remote reservoir as the DT125R shock accomplishes all this in a single shock body as they figured that would be all 17-year-olds needed. The DT200R and most MX bikes have a remote or piggyback reservoir to increase oil volume and reduce overheating/fading during serious off-road riding. TBH I've never had an issue with a stock DTR shock so as long as there's no pitting on the shaft and no visible leaks I think you're good to go.
                                        https://www.youtube.com/watch?v=GBcRBOikb8c
                                          @HOTSHOT-III
                                          OK, that’s interesting! I knew that they weren’t ’serviceable’ but I didn’t realise they were charged with pressure in any kind of way. Probably why they have the ‘explode~explodey’ sticker on them! 🙂 I wonder how they charge them? They usually have a pfhiefer (spelling!😛) valve on them don’t they?…
                                          Cheers bud! 👍 …
