  4. So Close!...
So Close!...
1.1k Posts 26 Posters 666.5k Views
    Do the piston rings go a particular way on an Athena piston? I can’t see any difference between them. The only thing that might be a marking is a [ kind of shape, but horizontal. That’s only on one ring though…
    Oh well, I chucked it on anyways!…
    I did have help from a friend though…
    Taught me how to feather the throttle 🙂 …
      Don't chuck it on FFS! Amatuers! Place it on lovingly. Caress it, hold it, love it!
      Does look good though! I mean fair play to you and your workbench! You're doing it guerilla stylie.
        #803
        Chuck is a term of affection from me! 🙂 Seriously! All new bearings and seals throughout, new Jamasil crank. I can’t afford to be ‘blasé’ 😳 I even removed, cleaned the threads, greased and re-inserted the barrel base studs and dowels to a tightness that they’re removable in the future, if needs be. The head studs I always remove and service…
        Labour of Dove 🤔 …
        It’s getting there! Little by little, weather permitting…
        WTFux! it’s just started raining! 🤪 …
          Doing a great job bud! Keep it up.
            #805
            The umbrella? 😜 …
            Blaster 200 small end bearing didn’t fit. Was too wide to fit inside the piston. Luckily I had a dtr bearing that has wider roller/needles than the others I’ve got. Even with a bit of side to side play it still has good coverage of the conrods top eye width…
            PS I just noticed that the Athena top end gasket set doesn’t include the orange PV bush seal! For nearly £50 you’d think they’d include it?!…
            S MadGyverM 2 Replies Last reply
              The umbrella? 😜 …
              #806
              Ready to drop in. All torqued and tight! Only the 2T pump left to fettle, I’ve got 3 to find the bestest one. I can finish off the tank of premix anyways 🙂 …
              Just gonna replace the rear shock while the swingarm bolt is out. It doesn’t feel broken but it was crusty 30,000 miles ago. So, yeah! There is that…
                @MadGyver
                Nitro, What is dat? Model fuel?…
                MadGyverM
                MadGyverM
                MadGyver
                @MadGyver
                Nitro paint thinner. It dillutes paints and a lot other uses.
                  The umbrella? 😜 …
                  MadGyverM
                  MadGyverM
                  MadGyver
                  The umbrella? 😜 …
                  To fit the small end bearing from the Blaster you need to file each side inside of the piston 0,5mm. To be on the safe side I removed 0,75mm from each side for when everything heats and diolates.
                  • MadGyverM MadGyver
                    The umbrella? 😜 …
                    #809
                    @MadGyver
                    Fux! I wish I’d known that before I buttoned it all up! 😉 …
                    I’ve been on a bit of a tight deadline with it, weather wise. Not to mention the strange noises I’ve been ignoring coming from my existing engine. I can’t wait to do an autopsy on it!…
                      @MadGyver
                      #810
                      A little tip for people like me who have to ‘apply’ bearings with a hammer and ‘drift’ 🙂
                      Use a jubilee clip to hold in place whatever tool you are using, in my case a screwdriver…
                      Make sure it’s clear of the bearing, especially the race. It allows more of the force to be applied downwards, without worrying so much about slipping and destroying the roller~race. It makes the blows less ‘tentative’, more effective. It really makes a difference…
                      If you have a suitable tube then ignore me! 😉 …
                        I just bought the stearing stem bearing tool.
                        https://www.dirtbikexpress.co.uk/products/apico-steering-stem-bearing-installation-tool?variation=51559
                          #812
                          Then ignore me! 😜 …
                          Just found this while looking for some connector blocks and trying to find the proper gauge/amp wire:
                          early loom
                          OllieDTRO S 2 Replies Last reply
                            Then ignore me! 😜 …
                            early loom
                            OllieDTRO
                            OllieDTRO
                            OllieDTR
                            @SpookDog
                            He makes all types of wiring looms for the dts and he’s local to us
                              Then ignore me! 😜 …
                              early loom
                              #814
                              Just trying to muster energy to strip down for the new motor. Poor old frame hasn’t been tret well by three winters worth of road salt!…
                              Fuxin surface rust everywhere. I dread to think of inside the tubing. I need to get it dipped and coated professionally this spring-summer…
                              I’d like to have a different frame to work on really, If anyone knows of a usable frame for sale, please let me know. 👍
                                @SpookDog I was thinking of getting another frame. I'd like to reshell my '05 into an '88 🤣 By 2028 it'll be MOT/Tax exempt 😛
                                  #816
                                  Like you need to pinch pennies! 😜
                                  I don’t care what year it is as long as it’s not an RE…
                                  Going to peices!…
                                    Going to peices!…
                                    @SpookDog It's not about money, it's the act of having to keep going there. You should have seen the state of my bike when I got it back from them last time. UTTER MONKEYS! Dangerous it was to ride home. And the response "Yeah it would be!" It was fucking sound when I gave it to you 'ya cunts!
                                    Anyway, fuming to say the least. And dude! I live a VERY cheap life. Don't smoke, don't drink, don't do drugs (like my coffee), don't drive, don't ride my motorbikes (I cycle/run everywhere). I don't go on holiday and I eat baked beans most evenings, not literally but the cheaper the better. What's the result, a few shiny bolts come pay day. If you examine any photo I take of my bikes, they're usually in the same spots. So I pinch every penny for my addiction.
                                      #818
                                      Woah there Tiger! I didn’t mean to hit a nerve! Honest! 🙂
                                      ☮️ peace!…
                                      I’m getting there! I hate working in the damp though! Everything is filthy. I’ve had to scrub up my hands four times already!…
                                      PS RE frames are different aren’t they?…
                                        ☮️ peace!…
                                        @SpookDog Yeah man, no sentiment over text. I'm angry about getting my bike back from the MOT'ers in a sorry state not about penny pinching 🤣
                                          I actually believe that 2T’s are ‘rider sensitive’. Other people can upset the whole… vibe, for want of a less hippy word…
                                          Did they work on it at all? Or just manhandle it 🙂 …
