  4. Engine bearings
Engine bearings
5 Posts 3 Posters 857 Views
    jonne123
    Does anyone have list of dtr engine bearings sizes? Especially the 2 needle bearings sizes
    CalumC NottsbikerN 2 Replies Last reply
    • J jonne123
      @jonne123 Pretty sure the bearings are on this site. Not the needle bearings though. I'd imagine they're standard size, just take them out and measure them.
      • J jonne123
        NottsbikerN
        NottsbikerN
        @jonne123
        I've always taken the old bearing along to a bearing supplier and got them to sort me out with the correct one/s
        Make sure that you get the correct size and grade so that they not only fit but are up to the job required of them
        • NottsbikerN Nottsbiker
          @jonne123
          @nottsbiker DTR has an odd size. They are on PJME but money can be saved if you go to SimplyBearings
            NottsbikerN
            NottsbikerN
            @calum
            Yes found that out to my dismay once - think they are 1mm narrower than the nearest commonly available bearing.
            Why wont these casings go back together.....
