  4. JB Weld Crankcase Fix
4 Posts 4 Posters 847 Views
  • jimmydc98J
    jimmydc98J
    jimmydc98
    Hello has anyone used JB Weld before and do you think it can repair this it’s on the crankcase where the oil drain screw is, I’ve order some off amazon and should be here Friday.
    Was wondering why I paid £40 for a bottom end seemed really cheap shat out the gearbox though I’ve got the selector and the selector forks but not the actual gears etc but there was loads of metal shavings in there I guess it could have drained all its oil over time and they kept running it as I know these gearbox’s are supposed to be indestructible.
    DT200WR 1997 - New Project
    DTR 125 2002 - Project
    DT 125 LC 1986 - Old Bike
    CalumC S NINJAN 3 Replies Last reply
    • jimmydc98J jimmydc98
      @jimmydc98 Was it not advertised as such?
      That's bang out of order.
      I bought something similar years ago
      Bought a working engine only to find the connecting rod shot through the bottom end ruining the cases.
      I managed to get good money off the engine mind you, enough to get new cases.
      I would just get it welded up properly if it were me.
      Remember the cases will expand and contract with heat. So eventually it will crack again.
        @jimmydc98
        Get it tig welded. Try any garage, engineering firm. They’ll probably do it for the price of a beer...
          @jimmydc98 As @jimmydc98 says you would be far better off getting it TIG welded, as that would be a much stronger and more durable fix. I've used several JB weld epoxy's / adhesives and have never found them to be any good. They do not seem to stick or repair stuff as stated, so I would steer well clear of them. I have tried this stuff tho and can recommend it;
          https://www.ebay.co.uk/itm/VersaChem-Steel-Weld-Epoxy-Black-2hr-Set-25ml-47709-VC-Automotive-Industrial/362460351914
          The TIG welding would be your best bet tho IMO. 😉
