  4. Tight crank shaft nut
10 Posts 6 Posters 4.0k Views
  • LJK_hunterL Offline
    LJK_hunterL Offline
    LJK_hunter
    So I'm doing my first engine rebuild and I'm stuck at undoing be crankshaft nut, I cannot get it to move, is it supposed to be extremely tight? The one on the other side wasn't anywhere near as tight.
    • LJK_hunterL LJK_hunter
      @LJK_hunter The othet side has a tab washer to stop it coming undone. The flywheel nut should be tightened to 60nm approx. Although it's possible that it's has tightened due to the reciprocating mass of the wheel.
        LJK_hunterL Offline
        LJK_hunter
        There wasn't a tab washer on either side but this is the side that's tight.
          Fair enough, just checked my engine builds that is correct F
          • MightymanM Offline
            MightymanM Offline
            Breaker bar should do it no problem.. I found it easier to break those nuts by putting the engine back in the frame temporarily.
            • R Offline
              R Offline
              Raydt
              Put the clutch basket back on and wedge a piece of hard plastic between the gears, i use a small lump of nylon, then it should come undone with a breaker bar.
              Or cheat and use an air rattler/windygun.
                I Was doing a full rebuild so it was bar in small end eye and two blocks of wood as to not damage the crankcases. But any of the other methods will do it.
                ConnorDTRC 1 Reply Last reply
                  LJK_hunterL Offline
                  LJK_hunter
                  Got the nut off now, used
                  @MIGHTYMAN 's advice and put the engine back in the frame. Thanks guys :)
                    ConnorDTRC Offline
                    ConnorDTRC Offline
                    ConnorDTR
                    @Calum Exactly how i did it. Had to get a massive foot long 1/2 inch breaker bar to remove it. was very tight!
                    • AndyYamA Offline
                      AndyYamA Offline
                      AndyYam
                      I ended up using a bit of alluminium between the gears and an impact gun on the nut. A bit pikey but it did it :)
