  4. DT 125X Head light
DT 125X Head light
7 Posts 3 Posters 1.5k Views
  • W
    W
    Waggstar
    Hi there am doing a restoration on a dt125x and am going threw the electrics and every thing is working ok part from the main head light, the bulb is ok was just wondering if the engine needs to be running for this to be working with it being a electric start, any help would be great before I start losing the plot...
    markus.wM 1 Reply Last reply
      On the standard CDI, the headlight comes on with the engine, then it stays on after the engine has been killed.
      With the Zeeltronic ignition it is only on with the engine.
      • CalumC Calum moved this topic from General Discussion on
      • W
        W
        Waggstar
        It is the standard cdi and the bike had a full rebuild and hasn't been running for a long time so when am ready to run the bike it should work. cheers for your info.
        • W Waggstar
          markus.wM
          markus.wM
          @Waggstar headlight runs off the stator not the battery so the engine does need to be running.
          • markus.wM markus.w
            @markus-w DTX/DTRE works differently to the DTR.
              markus.wM
              markus.wM
              @Calum so they run off the battery?
                My RE lights would run regardless of engine running, until I swapped out the Zeeltronic.
