  4. Gear indicator
Gear indicator
7 Posts 3 Posters 1.2k Views
  • VcelickaV Offline
    VcelickaV Offline
    Vcelicka
    Hi guys, i was wondering if i could get gear indicator on my dt? Does anyone have one or some info on them?
    • VcelickaV Vcelicka
      @Vcelicka
      No, you would need a sensor built into the gear selector barrel, or rod/forks. Like the neutral switch but more. Then you would need an electronic control unit to count the gears and know when you are shifting up or down. Then a display that would fit in with the rest of the โ€˜dashโ€™โ€ฆ
      You can get air conditioning though! ๐Ÿ˜œ โ€ฆ
      VcelickaV 1 Reply Last reply
        @Vcelicka
        VcelickaV Offline
        VcelickaV Offline
        Vcelicka
        @SpookDog
        ๐Ÿ˜‚ ok thanks for the reply
          Why couldn't you just use one of these?
          https://www.healtech-electronics.com/products/gipro/gpxt/
            My bad, I didnโ€™t know such things existedโ€ฆ
              Uses a tachosensor/speedsensor and clutch.
              Looks snakeoil to me, but always comes up on my eBay feed for Aprilia RS/Cagiva
                Yeah, I just skimmed through it. I wouldnโ€™t touch it with a shitty stick! ๐Ÿ˜œ
                Iโ€™m embarrassed to admit that I sometimes forget what gear Iโ€™m in, not often! But trying to pull away from the traffic lights in 3rd is not a good look ๐Ÿ˜’ โ€ฆ
                It always seems to end up the time it wonโ€™t go back down into first, I end up rocking the fuxor backwards and forwards to try and get it to snick into gear! ๐Ÿ˜
