Navigation
    • Register
    • Search
    Help needed
    Brakes
    4
    6
    1179
    Loading More Posts
    • V
      vtrn_raptor last edited by
      How do you torque the barrel bolts as the power valve is in the way and I can't put a socket on
      • Calum
        Calum last edited by
        Yeah it's pretty shit, just have to make do with a spanner a d FT
        • GoProKid95
          GoProKid95 last edited by
          I would suggest the same as Calum, they probably don't have a torque setting, if they're the bolts/bolt that I think you're on about!
          • V
            The ones I'm talking about are the ones that attach the barrel to the engine casing and will a spanner be okay yeah
            Calum 1 Reply Last reply Reply Quote 0
            • Calum
              Calum @vtrn_raptor last edited by
              @vtrn_raptor Yeah spanner will be fine.
              Be sure to tighten in sequence as to not to distort the aluminium
              1 Reply Last reply Reply Quote 1
              • U
                UKBikeLife last edited by
                Hi callum, you based in gloucester? Was wondering if you could help me as wanting to mount rs125 front brake on my DT
                Thank you & merry chrismas
