  4. What damage have I done?
38 Posts 2 Posters 26.8k Views 1 Watching
    Nice, keep us posted. Any problems throw up a thread. ☺
    • M Offline
      M Offline
      Matt47
      Well I finally got myself organised and have everything ready for the rebuild 7 months later! :-S
      Crank has been rebuilt (not by me!), barrel/head skimmed, powervalve cleaned, got full seal kit and full Athena gasket kit ready to go... Now I just need to remember where everything goes. :-))
      • M Matt47
        @Matt47 it's fairly straight forward but do shout if you need help.
        • M Offline
          M Offline
          Matt47
          Ok, so my next silly question is... How do I remove seals the correct way to avoid damaging anything?!
          Think I have read that you can use screws to give yourself something to pull on - is this correct? Not keen on digging them out with a flat-head (unless they pop out easily).
          You can probably tell I'm a bit nervous about the whole thing, guess I need to man up haha! 😛
          • M Matt47
            @Matt47 I always had access to the seals from behind. Aka if they are the main bearing seals then removing the main bearings will give you access to them.
            • M Offline
              M Offline
              Matt47
              Ah, makes sense thanks!
              There was me thinking I had everything on my rebuild list, and I forgot to get the other bearings...
              All remaining bearings seem to be in great shape, but I guess I need to weigh up whether or not to do a full rebuild without all new bearings. Is it worth the risk?!
              • M Matt47
                @Matt47 What bearings need replacing?
                The gearbox bearings cost 20 quid. It would be silly not to sort those out st that price.
                If I were splitting the cases then I would just replace the bearings. But that's me.
                • M Offline
                  M Offline
                  Matt47
                  I only have the 2 main bearings for Crankshaft, and the top end stuff.
                  I'll have to commandeer the oven once my wife has gone to bed, and get them all out and have a proper look at them! They all feel/look in good nick but I might as well take them out anyway to make the seals easier to change.
                    As said, for their cost I'd do the gearbox bearings.
                    • M Offline
                      M Offline
                      Matt47
                      Yeah I suppose so, especially after seeing the post on gearbox bearings (quarter of the price of what I can find in France - and that includes postage from UK).
                      Disappointed that I overlooked these when ordering, but it would annoy me more if I didn't do it right after it has sat in bits for 7 months plus!
                      Cheers for all your support mate, will hopefully get them ordered up soon.
                        Simplybearings yeah? Grab all th Koyo bearings
                        • M Offline
                          M Offline
                          Matt47
                          Yeah, that's the one - amazing value once you know what to look for! €105 for 2 genuine Crank bearings or €28 for 2 koyo shielded (which were what mine were).
                          • M Offline
                            M Offline
                            Matt47
                            Tonight I heated up the crankcase halves to remove the bearings, and got all out apart from the 2 in the picture.
                            http://i1377.photobucket.com/albums/ah75/MatthewT47/20150124_144844_zpsnakligp9.jpg
                            How do I go about getting these out, as they are only accessible from one side?
                            Cheers, Matt
                            ps. sorry about the date on pic lol,
                            • M Matt47
                              Cheers, Matt
                              @Matt47 i lay the crankcase faced down. With enough heat the bearing simply dropped out into the oven.
                              It was getting it back in which took a bit of skill.
                              • M Offline
                                M Offline
                                Matt47
                                Ok cheers, will try again tonight. Obviously needs more cooking - gave it 30min at gas mark 1.
                                • M Offline
                                  M Offline
                                  Matt47
                                  So I tried again and no joy, then left it in almost an hour and the only thing that happened was I melted stuff unexpectedly... Guess i will have to take it somewhere to get it removed.
                                  Meanwhile, does anyone know what this and the other needle rollers are so I can get them ordered from simplybearings?
                                  • M Matt47
                                    @Matt47 should only need 10 or so minutes...looks like you will need a hydraulic puller. They can be had off eBay for 40 quid. Don't knoe how good those ones are though.
                                    • M Offline
                                      M Offline
                                      Matt47
                                      Yeah a blind bearing set would be cool, but a decent one is big bucks - and it's not an everyday job for me! Cheap tools are great if they work but will probably get someone to do it rather than take the risk.
                                      I even tried a rawl anchor on a diy sliding hammer and this just broke one of the collet parts off the bolt rather than move the bearing - this thing is stuck solid!
                                      Bloody thing is driving me potty!!!
