  4. No exhaust gasket erratic revs?
30 Posts 5 Posters 7.4k Views
  • declanD Offline
    So my bike had no exhaust gasket I rebuilt it and forgot to put the now one on I'll be doing that soon but I just read that it makes the bike lean and causes erratic revs is This the cause of my running problems?
    N 1 Reply Last reply
      @declan I know this is common sense, but if you reinstall the gasket and your problems go away then yes you have solved your erratic running problem. If the problem still persists after you have fitted the gasket, then it's something else causing the running problem. I would refit the gasket ASAP and go from there before you do any more tinkering. Yamaha spent a lot of time and money designing the bike, having a piece of the puzzle missing may be why you are having problems??? 😉
      • N NINJA
        @CYBER-NINJA thanks for the reply do you run a dep pipe by any chance? Do you think you could send me a pic of how your chamber bolts to the frame
          @declan I sold my DTR 9 months ago dude, but from memory there was a single bolt which bolted to the frame just under the seat. It was just the same as the stock pipe.
            I can't remember on the DTR's but there RE bolts twice, once at the front and another under the tank.
            However they both didn't work so I just bolted it by the exhaust flange and then by the end can.
            Seeing how the DEP is SOOO much lighter it was good enough.
            • A Offline
              A Offline
              andrewj1680
              wrote on last edited by andrewj1680
              The new dep front pipes only have the front exhaust mount they seem to of done away with the back mount possibly to keep the weight down I can post a pic need be
                @Calum see this is what I mean the mount don't line up
                  @declan Look at this thread bud, you can clearly see the DEP mounts;
                  https://dt125r.co.uk/topic/774/just-a-quick-update-for-those-who-care
                  A declanD 2 Replies Last reply
                  • N NINJA
                    A Offline
                    A Offline
                    andrewj1680
                    @CYBER-NINJA pretty sure that isn't a dep
                    • A Offline
                      A Offline
                      andrewj1680
                      Mine hasn't got a mount there
                      • A Offline
                        A Offline
                        andrewj1680
                        Got the front only
                        • A andrewj1680
                          @andrewj1680 Your right upon closer inspection it looks more like a Big One pipe - my bad!!! 😞
                          A 1 Reply Last reply
                          • N NINJA
                            A Offline
                            A Offline
                            andrewj1680
                            @CYBER-NINJA looks a nice pipe tho whatever it is 👍
                            declanD N 2 Replies Last reply
                            • A andrewj1680
                              @andrewj1680 shit so your telling me I don't have a dep pipe 😞😞😞😞😂😂😂
                              • N NINJA
                                @CYBER-NINJA that's my bike bud 😂😂
                                A N 2 Replies Last reply
                                • A andrewj1680
                                  @andrewj1680 Yep nice and shiny, the rear silencer is defo a DEP, which is what threw me. There aren't too many performance pipes for DT's around these days, so it's either a DEP, Big One, Giannelli or perhaps an Arrow? My money would be on the Big One tho. 😉
                                    So from what I hear, the Big One Spannys weren't the best.
                                    But no that isn't a DEP pipe.
                                    I was very pleased with my DEP pipe, great performance and sounded sweet.
                                      A Offline
                                      A Offline
                                      andrewj1680
                                      @declan is it stamped as a dep mate?
                                        @declan So which front pipe is it dude???
                                          A Offline
                                          A Offline
                                          andrewj1680
                                          @Calum I can't complain with mine mate sounds great and the bike performs better than it did with the standard pipe I kind of wish I had bought the dep wr200 pipe rather than go with the fmf now
