  4. Indicators?
Indicators?
8 Posts 4 Posters 1.8k Views
  • declanD Offline
    Will the indicators still work say for instance the front two are connected but the back ones aren't should they still work mine do nothing at all?
    • MightymanM Offline
      MightymanM Offline
      I tried swapping my broken ones out for LED ones the other day, if any were disconnected, they would all stop working.
        NINJAN Offline
        NINJAN Offline
        @declan As long as they are earthed correctly they should work in pairs, but only if they are bulb units. If you have swapped to LED's then no they will not work individually.
        declanD 2 Replies Last reply
          @CYBER-NINJA yesss hopefully mine will work then thank you lads
            @CYBER-NINJA so swapping around the wires I can get the left indicator to light up solid but only when switching the right indicator but the light stays solid?
              Again it doesn't work like that.
              The circuit works off the impedece oft the whole circuit.
                @Calum sooooooo? 🤔
                  @Calum sooooooo? 🤔
                  @declan So removing items from the circuit alters the impedence of that circuit.
