  4. Dt125r/wr200 build
Dt125r/wr200 build
14 Posts 5 Posters 3.2k Views
  • A Offline
    A Offline
    andrewj1680
    0_1500155017901_20170715_184417.jpg 0_1500155052609_20170715_184427.jpg 0_1500155086576_20170715_184440.jpg
    Finally got around to stripping 1 of my dt125r low mileage just to ensure i had a good base so the build starts here
    • A andrewj1680
      @andrewj1680 you keeping the engine as it is of swapping it out?
      • A Offline
        A Offline
        andrewj1680
        I have a fresh built forged wr200 engine with ported cylinder and modified squish band that i plan to run
        • A andrewj1680
          @andrewj1680 Yes mate sick.
          • A andrewj1680
            @andrewj1680 soooo what you doing with that dt engine 😉😉
            • ZrakoZ Offline
              ZrakoZ Offline
              Zrako
              I believe you going to use the standard forks and maybe sell the usd ones? 😅
              1979 Jawa Mustang 50
              2003 Gilera DNA 125 R.I.P
              2015 Keeway TX 125 SM
              2006 Yamaha DT 125 X
              • A Offline
                A Offline
                andrewj1680
                The usd forks are going to be part of the build they are wr items along with the complete rear swing arm setup, the engine will become a spare as it has a mick abbey tuning modified cylinder and head and the bottom end has done less than 5000 miles so not really worth parting with.
                • A andrewj1680
                  @andrewj1680 how much does it cost to get your cylinder done like yours and is it worth it?
                  • A Offline
                    A Offline
                    andrewj1680
                    £170 he normally charges, highly recommend it. Totally changed my bike it pulls all the way through the rev range even in top gear where it used to runout of steam, hes also done my wr cylinder and head i was that impressed with the difference it made
                    • A andrewj1680
                      @andrewj1680 nice! Where's he based
                      A 1 Reply Last reply
                        A Offline
                        A Offline
                        andrewj1680
                        @declan Stockton on tees mate
                        terry.tzT 1 Reply Last reply
                        • A andrewj1680
                          terry.tzT Offline
                          terry.tzT Offline
                          terry.tz
                          @andrewj1680 Stockton Mick Abbey Harrogate isn't he
                          • terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            google tells me the same Harrogate
                            • terry.tzT terry.tz
                              A Offline
                              A Offline
                              andrewj1680
                              @terry.tz hes moved from there mate
