  4. Temp gauge trouble shooting
103 Posts 10 Posters 51.6k Views 1 Watching
  • terry.tzT
    terry.tzT
    terry.tz
    ???? I'm confused at what your asking him
    • terry.tzT terry.tz
      Stone cold it sits on 20.c every pic I can find shows the needle on exactly that
        Jens Eskildsen
        Havent noticed, but I tested at boiling temp and it was spot on.
        • J Jens Eskildsen
          @jens-eskildsen mind looking for me when you can?
            Jens Eskildsen
            Yeah, problem is, its often around 20C in my workshop.
            • J Jens Eskildsen
              @jens-eskildsen some help you are 😂😂😂 np man just let me know if you find anything out
              terry.tzT 1 Reply Last reply
                terry.tzT
                terry.tzT
                terry.tz
                @declan maybe it's a slight miss measure they are made in China and cost next to nothing do they measured by pressure
                  @terry-tz no it's temp I think it's just the way they are set they are all like it
                    terry.tzT
                    terry.tzT
                    terry.tz
                    yea you can measure temp with pressure @declan don't know how accurate it is low temps that what made me wonder but it's probably just inaccurate at low temps dou to chinessium
                      @terry-tz 😒
                      • terry.tzT
                        terry.tzT
                        terry.tz
                        what temp your bike get up to anyway
                          @terry-tz no idea
                            @terry-tz no idea
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @declan ???
                              @declan ???
                              @terry-tz I got no idea how hot it gets I have no way of knowing I haven't used it since installing that cap
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @declan are ok
                                  Jens Eskildsen
                                  Also, when the bike is shut off, them temperature gauge isnt touching the water properly.
                                  Mine was dead set at 20C yesterday, but so was actual temp.
                                  • J Jens Eskildsen
                                    @jens-eskildsen if you have the same one as me I'm certain that it will always be on 20 when cold
                                    • terry.tzT
                                      terry.tzT
                                      terry.tz
                                      metals don't react very linearly at low and high temps this is a lie but not in a way that would be accurate in a small simple device or respond fast hence engine thermostats are sh!te I'm assuming they are made the same way so instead of opening they move the needle so it's probably just shit at low temps until like 40-50c total guess hope I'm not teaching to suck eggs I'm not knowledgeable on this subject just think it make's sense
                                        Jens Eskildsen
                                        Mine seems to work fine when tested, and very linear in movement, when compared to the one in the instrument.
                                        They seem to follow each other fine.
                                        For me, its well worth the few bucks.
                                        Test the gauge in the frigde/freezer, or in boiling water.
                                        • J Jens Eskildsen
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          @jens-eskildsen I don't have one yet to test or I would out of curiosity I will anyway when I get one lol
