  4. Thermo unit Earthing help required.
16 Posts 5 Posters 4.5k Views
    @tdrgreg2 starter relay might be stuck closed
    Yamboy46Y
    Yamboy46Y
    Yamboy46
    @finnerz89 could you please go further in depth
      @finnerz89 Would it though? Because the starter button is switch live is it not?
      F 1 Reply Last reply
        @calum yeah, it has a direct feed from the battery, if the contacts inside are welded together then as soon as you put power to it the motors going to turn
          @finnerz89 Sorry I thought he meant that the button works if the switch is on or off.
          Just read it again, yeah what you said sounds about right
            @calum needs a twat with a hammer as we say in the trade!
            I'm usually the twat 🤣
            • NottsbikerN
              NottsbikerN
              Does this mount to the coil bolt. Looks like it fits onto something. The loom on the Belgarda TDR is slightly different to the DTR ones.
              • NottsbikerN Nottsbiker
                @nottsbiker I thought regulator mount, looks like the one on my DTX. Either way anywhere on the frame should do
                • NottsbikerN
                  NottsbikerN
                  Regulator mounts differently on the TDR to the X. Yours iirc it's on the rad frame and the TDR one fits like the DTR under the seat and is held on with a screw that doesn't hold anything else on
                  Yamboy46Y 1 Reply Last reply
                    Yamboy46Y
                    Yamboy46Y
                    Yamboy46
                    @nottsbiker would you happen to know how the starter relay is wired up . Amy pictures would be a bonus.
                    • NottsbikerN
                      NottsbikerN
                      Is it not in that pdf i sent out last week?
                      Iirc it's connected to the battery via a heavy duty red (positive) cable which then goes to the starter motor. I think that the black (earth) cable goes from the battery to the solenoid then from there attaches to the engine. There is also a two wire plug that goes to the solenoid which is the lower power switching signal which is connected to the starter button.
                      No pics I'm afraid I'm away on holiday at mo
