  3. Carburetor
  4. Cutting top of airbox
16 Posts 9 Posters 4.6k Views
    Well I personally think it's butchering the bike. Personally I just use a pod filter.
    • rogeringR
      rogeringR
      rogering
      True mate I have a pod filter but as mine just for off road I need a level of water protection but only got airbox but you have thankfully sorted out the boot I needed for cars to box an I'm greatfull for mate
        My stock bike runs better with the snorkel removed, and the hole in the airbox enlarged.
        I have added a little splash guard to keep the water away from the opening.
        • Glynn123G
          Glynn123G
          Glynn123
          I know this is old, but to help future readers, I have very good results with snorkle removed and 250 main jet, this is paired with a full system.
          • Glynn123G Glynn123
            @glynn123 does the snorkel just pull out lads
            R 1 Reply Last reply
            • NottsbikerN
              NottsbikerN
              Yes, might be glued in like the airbox halves are glued / screwed together
              • Glynn123G
                Glynn123G
                Glynn123
                Should just pull out, will be stiff due to the big lip mind, mine came out fine.
                  @glynn123 just asking since when I tried I couldn’t get it out and didn’t want to rip it
                    Put a flat blade between the air box and snorkel and leverage it out. Don't just tug it out.
                    Personally I prefer my bikes with Snorkels in as they ride better.
                      @calum thanks man and yeah worth a try though while I have it apart
                        R
                        R
                        ryancole2001
                        @declan yes it pulls right out
