  4. Recommended screwdriver for clutch cover?
10 Posts 4 Posters 1.1k Views
  • ricky0115R Offline
    ricky0115R Offline
    ricky0115
    These screws are awful, what size should i use? ph2 worked on 3 but the rest are way too tight I dont want to round any off!
    • F Offline
      F Offline
      You need an impact driver really, then change them for stainless cap head screws. If they chew up completely you could cut a slot in the head then use a big slotted screwdriver.
      Or maybe try tapping them round with a centre punch?
        @finnerz89 that has saved my ass so many times never done a clutch though but yeah impact is ideal
          ricky0115R Offline
          ricky0115
          Ended up tapping a screwdriver whilst twisting & replaced them with hex heads! Cheers guys
            Definitely replace some stainless bolts lol.
            Just be careful how tight you do them, the bolts will be stronger than the engine cases, and you can risk stripping a thread.
            ricky0115R 1 Reply Last reply
              ricky0115R Offline
              ricky0115R Offline
              ricky0115
              @calum yeah I was very careful not to over tighten them, who puts screws on an engine casing anyway lol
              • ricky0115R ricky0115
                @ricky0115 Yamaha?
                  @ricky0115 Yamaha?
                  ricky0115R Offline
                  ricky0115R Offline
                  ricky0115
                  @calum should I of replaced the gasket? The old one was still in tact so I reused it oops
                    @ricky0115 nah you will be good
                      ricky0115R Offline
                      ricky0115R Offline
                      ricky0115
                      @declan Phew, thanks
