Brake pads
Going to change the pads on my 88 bike, with the hoses plenty of feel at the lever but not as quick to stop as I remember, pads are at least12 years old so going to change. Used EBC HH on big bikes ,seen red EBC pads on eBay? Any good or recommendations?
The discs are relatively new, have ordered some red EBC pads, think the existing ones are past their sell by date, should have done it when I rebuilt but plenty of meat on them. Will give discs a good clean prior to fitting.
Thanks -
Brake pads? I thought 1st gear was what we used to stop.
I remember my DTRE stock brakes, man they were dangerous!
@declan As in eventually I just used severe engine braking to stop, and that is no word of a lie.
Have the braided lines and new fluid, just a lacķ of forward momentum stopping power, no sponginess at lever, just feels like the pads are slipping over the surface more than gripping like they are really hard.
Fitted the EBC red stuff pads, braking now what it should be, even the back brake! Brakes best they have ever been, and so they should be with braided lines and new fluid. Worth all the effort rebuilding the calipers and master cylinders. EBC pads get my vote, can only assume old pads were contaminated along the way. Luckily the discs weren't glazed, running better now with the power valve seal done as well.
@oldman Although they do not last as long, the EBC pads are well worth the couple of extra pounds. They greatly improve braking along with the braided lines and Dot 5.1 fluid, as you have discovered my friend. And any improvement you can get with the stock discs and caliper set-up is a god send for-sure!!!
@ninja You gotta be careful with DOT 5.1 oil!!!
It's not the same as DOT 3/4 and can adversely damage the seals on the caliper if they have not been designd with 5.1 in mind.
@ninja Unless it explicitally says so, I wouldn't have thought it.
It's mroe than just the piston seals, but the master cylinder seals you have to think about.
