  4. Starter motor just spinns around
12 Posts 6 Posters 1.6k Views
    Should be possible to have the Starter motor rewound.
    It could be the gears that it's connecting with.
    That would be where I'd start first.
    @calum I opened the engine cover and sprayed dim lubricant into the starter. I'll see how it turns out
      @irongamer727 Hhm, I would rather investigate furuther if it were me.
      It's Two bolts I beleive t remove the starter and make sure none of the cogs have deteriorated
        My starter motor have always been a bit chinky. Sometimes it worked sometimes it didn't. It just spinns and is not cranking the engine. Now, it rarely ever cranks the engine. Can I dismantle the starter and lubricate it somehow?
        @irongamer727 All together now - You spin me right round baby, right round. Like a record baby right round, right round round round. 😆
        Seriously tho, sounds like somethings broken inside and/or worked loose? I would remove the starter and investigate it properly dude. Just spraying lubricant in there will only grease the moving parts, albeit original or damaged???
        terry.tzT 1 Reply Last reply
          terry.tzT
          terry.tzT
          terry.tz
          @ninja stick to your day job :rofl:
          • terry.tzT terry.tz
            @terry-tz I would but that's very boring and us average Joe's, aka humans need levity to make the day go quicker for-sure!!! 😉
              @ninja you have no idea how many times I’ve had that song in my head when I read this post I was gonna post about it earlier lol,oh and btw I like your singing 😏
                Worn out sprag clutch? Sounds like it started skipping, and now not gripping at all.
                • Irongamer727I
                  Considerably better after the lubricant. But it is going to need some more attention
                    @declan Sing it with me bro - You spin me right round baby, right round. Like a record baby right round, right round round round. 😆
                    https://www.youtube.com/watch?v=PGNiXGX2nLU
                      @ninja just listened to the full song,was pretty jamming and that hair was magnificent 😂😂
