Best performance exhaust dt125
Any ideas? I know for a fact that the exhausts for at least mopeds and smaller machines differs quite a lot. Some are really well performing and some less. What do you guys think? Dep, Athena, Arrow, Gianelli, Big one and so on. (Don't comment and just say: "my Dep is the best") 😉
@irongamer727 my big one is the best 😏 depends what your looking for I think the big one is better for higher revs and dep is more low down but I don’t know the underslung pipes are the best from what I hear but that’s road bikes I don’t think it would be wise off roading with an underslung pipe
Big Ones are zee worst. From my experience in the past, Big One was better for mid range but totally kills top end.
DEPS are great, rev to the moon, but ultimately rust.
Underslungs offer the best performance as they don't compromise by wrapping around the frame.
I hear good things about FMF.
@calum underslugs are the pipes that goes "under" right?
I’ve ridden between most, the DEP expansion pipe design is the best..,
You just dont get the over rev abilty with the other pipes, which are all quite similar and designed for Mid range torque.
A custom pipe is the way to go tho.
@darty what about the famous Arrow. I've heard they tend to rust easily.
@irongamer727 yeh, they all rust like buggery.
The Dep is actually the worst for it if you dont look after the plating.
@darty I ment what do you think about the arrow exhausts? They must be the most well know at least
@calum Hi Calum, i've seen the FMF mentioned af couple of times here on the forum, do they actually make an bolt-on exhaust for the DT? I can't seem to find one myself at any dealers, nor on FMF's own homepage.
@calum and the wr200 exhaust works well on a dt125?
@irongamer727 Well this is it, I wouldn't have thought so. But you'd have to speak to someone who has ran that setup.
