  4. 1989 rebuild update
1989 rebuild update
127 Posts 14 Posters 81.4k Views 2 Watching
  • O oldman
    It's not the cable, it's the outer metal end that protrudes throughout the cable entry of oil pump. There is a recess in the end of this for a circlip to prevent cable being pulled out of the oil pump housing. On my 88 bike the length was perfect, meaning you placed the metal shaft through the housing and the circlip secured cable outer tight to the housing. The Yambits cable just did not work, did not pull oil pump pulley unless outer sheath pulled out of oil pump housing 8 to 10mm, also difficult to take slack out of cable at throttle end. Hopefully pattern part I used previously will be here tomorrow to compare, will post some pics when I go back I'm garage.
    #55
    @oldman I did have this exact problem I had to make an adjuster using a clutch cable adjuster
      Here is the caliper straight out of the ultrasonic cleaner ready for finishing, need a spray booth!0_1513105780208_received_10155357237199926-1200x750.jpeg 0_1513105792123_received_10155357234189926-1200x750.jpeg
        Cable adjuster wouldn't work, cable length is fine, length of metal insert to oil pump housing too long,
        • O oldman
          @oldman There is supposed to be a rubber o ring that goes on that metal insert FYI
            Thanks Calum, but the insert is about 8 to 10mm too long, I will post some pictures up as soon as I get a chance, grandad duty calls tomorrow so Thursday likely, should have repro cable by then as well.
            • O oldman
              @oldman no the adjuster was for the metal housing like I said the exact same problem I had the adjuster made it so I can either adjust the metal housing in our out more
                Repro cable arrived, see photo, with O ring perfect fit, I know it's not much, do you think original cable is designed for a bit of play in it?
                If I put a cable adjuster to correct to correct(?) fit would also pull on oil pump pulley opening oil pump prematurely, as fitted inner cable perfect length and opens oil pump in sync with throttle.
                  Don't forget, there were two types of oil pumps that came on these engines. Therefore I'd expect to see two different types of cables.
                  That bottom silver one looks more familiar to me, but I have the later engine. Earlier engines use different pumps.
                    @calum yeah I have the same pump as you
                      Both the Yamaha cable and Yambits (unuseable) cable same length spigot, oil pump came with bike and same as my 88 so no reason to suspect change there. Perhaps I am looking for a problem that does not exist. Repro received today fits perfect though, Yamaha cable operates throttle and pump in unison so no issues with suitability, only that the circlip indent doesn't locate near to cable entry near oil pump housing as per the repro used previously. Will give it some thought and probably leave original in place, maybe make spacer that fits inside oil pump housing.
                        Stripped the front brake caliper, in poor condition, dust seal filled with brake fluid and piston fitted back to front, you can see a bit of the piston seal in the dust seal groove. Sure the damage was done when the piston was fitted by whoever. Chucked the lot in the ultrasonic cleaner before I touch it, cleaner need fresh fluid anyway.0_1513284449187_20171214_201327-1224x1632.jpg 0_1513284468055_20171214_201334-1224x1632.jpg 0_1513284489831_20171214_201343-1224x1632.jpg 0_1513284506861_20171214_201352-1224x1632.jpg
                          This is the caliper after ultrasonic clean.
                          0_1513291995813_20171214_224839-1224x1632.jpg 0_1513292017354_20171214_224852-1224x1632.jpg
                            Calipers painted and rebuilt, fitted loose to bike, waiting for rear master cylinder hose to and front cable clip to arrive. Refitted carb with 240 main jet, again waiting for engine water hoses to arrive so I can fill and try starting engine (😨), speedo cable fitted and swingarm chain protector/upper roller fitted. Not too much to do now, wheels not back from Central yet and Galfer disc unlikely to arrive until new year.
                            0_1513549593410_20171217_142416-1024x576.jpg 0_1513549605072_20171217_143425-576x1024.jpg
                              Have had to endure Christmas crap all week, but SANTA did deliver the Galfer brake disc, and as I am on the nice list allowed time to secluded myself in the garage today with bikes and music. Downside is new hoses for RAD never arrived so had to reorder, sticking the old ones back on for now.0_1514109097462_20171224_094041-1024x576.jpg
                              • O oldman
                                @oldman I went with Galfer for my disc. Nice one!
                                  Looks good quality, not much more than standard replacement, mates choice (a good one) filled with oil and water after fitting hoses, all bled and started 3rd kick, sounds good. Exhaust can really tight fit onto expansion chamber so mounting holes not lining up,will get mini grinder out after Christmas. Spare wheels while waiting for rebuilt ones from Central Wheels, seems they are not quick either!0_1514136266083_20171224_170253-1024x576.jpg
                                  • V
                                    V
                                    vtrn_raptor
                                    Did you have to remove the old steering lock without a key or wasn't their one their before hand
                                      There was not one before, already taken out, going to do the 88 though which already has lock fitted , no key,
                                      • V
                                        V
                                        vtrn_raptor
                                        I need to get a new one brought the bike and didn't come with the steering lock key are they easy to remove without a key
                                        O 1 Reply Last reply
                                          I won't know until I do it, will have to get pin out of cover plate that fits in to frame and then drill lock out, should not be too bad (famous last words!)
                                          On the bike front waiting for wheels to come back, list of things to do very short now, have run engine right up to temp and sorted exhaust, fitted panels and tank to make sure all ok, need a better seat though, on my to do list.0_1514754557592_20171231_204744-1024x576.jpg
