  3. Dtr mileage
Dtr mileage
26 Posts 6 Posters 7.3k Views
    @calum so at say like 12k miles your still running perfect but have a spare set of rings can you throw them on and get another 12k out of your piston or does it not work quite that well
    @declan Try maybe once a year lol.
    But then my barrel has been ported, larger intake and exhausts port cause excessive wear to the rings. When you start tuning, throw reliability out the window.
    That said, didn't ride my bike this year so it won't need doing. And don't plan on using it next year, so I won't do it next year either.
    No, you definitely wouldn't want to be doing 24k on a factory piston. Buy forged components and they will last a lot longer, but it's all about tolerances.
    We are specifically talking 2 strokes here, but the principles apply to any mechanical engineering. So long as components are within tolerance, they should last.
    But anything can happen, including manufacturing defects. So it's completely up to the builders discretion whether a component can be reused.
      @calum so is my trip counter reading 40.6 too instead of 406
        @declan I don't know, is it? The last digit on the end is a decimal point.
          @calum if the last digit is a decimal point then yes it is
          • P
            P
            PJT95
            Bought my bike at 22k miles. Piston went at 26k and scored barrel. It was still on original bore too.. piston swapped and going strong again, currently at 29k miles.
            • P PJT95
              @pjt95 Yeah...but it's not going to be making full power. And it won't last that long if the barrel is scored. And I don't know about you, but the last thing I want is the engine seizing whilst I'm doing 70mph...
                @calum straight line ain’t too bad but on a corner is a death wish
                  @declan Although he was coming off a corner, it seized on a straight.
                  https://youtu.be/g5_A5oi7wC0?t=34s
                  I just don't think it's worth the risk. If the bike isn't tip top, don't ride it.
                    @calum personally I wouldn’t run a bike with a screwed up top end unless I don’t mind losing it
                    • P
                      P
                      PJT95
                      It was scored, I wasn't aware it was original piston until it went. I got it rebored and skimmed by Fahron Engineering so I'd say its in good shape now. Now I know how many miles this piston/ring and bore have done, I'll definitely be replacing rings when the time comes.
                      Mine seized on the way home from work on coming off an island doing 35-40mph, it deffo scared me.
                      • P PJT95
                        @pjt95 can’t imagine it’s very fun was the crank okay?
                        • P
                          P
                          PJT95
                          Crank and bearing looked/felt fine, never bothered to split it and take a proper look though. Not sure why it went, whether it was due to age ect. Although the wrist pin and small end bearing were VERY worn. It took a right big chunk out of the piston and most of it went out of the exhaust port.
                          Since I had the top end sorted it has been running like a dream.
                          • P PJT95
                            @pjt95 Ah ryt, you did get it rebored then. That's good news.
                            Rule of thumb, these engines, 30K on the bottom end. I'd say that's really when you should consider pulling the motor for a rebuild.
                            Now then can and will do more than that, it's just it is cheaper to rebuild the engine, than it is to replace the crank cases. So well worth doing before it goes.
                            The key thing is, sound. It should start to knock at idle. But when you do a ring change, just check the tolerances. There is no need to split the cases to check these things so that's a moot point.
                            Regardless of miles, you should always check the bottom end. Since the top end is reliant on the bottom end. Always worth replacing if in doubt.
                              @calum 30 000 Miles? 50 000 km?
                                My red 88 was at 30k miles when I replaced the speedo for new a few years ago
                                  Bottem end lasts for ages on theese things.
                                  With your input, this post could be even better đź’—
