  3. Top End
  4. pinned powervalve gap or no gap
15 Posts 4 Posters 3.8k Views
    @dan28 You need to wait for the upload to complete mate. What for the image to embed itself into the page before hitting submit Be paitient, you're working off a 2mb upload!
    dan28
    @calum said in pinned powervalve gap or no gap:
    Each time I try to upload its says the image is too large an doesn't embed it
    Not sure why I m using the same phone an has worked on here before
    declanD 2 Replies Last reply
    • D dan28
      @dan28 so when you line the pv up like your supposed to inside the cylinder it’s restricting still? If so I recently discovered the same thing with mine so I set it before the hole
      • D dan28
        @dan28 yeah it won’t work that way anymore
          @declan same for me
            @declan same for me
            @irongamer727 for the pv or pictures?
              @declan when aligned, the pv is not fully open.
                @irongamer727 yes my theory is it’s a cheeky restriction?
                  @declan naah. It is clearly evident on my Athena 170. That's no restriction in that case
                    @irongamer727 ooh wonder why it’s that way then?
                      I never go by the hole. Just match it with the exhaust port and away you go.
                      • D
                        dan28
                        the plastic pulley has to aligned with hole to be able to pin it though unless I glue a washer on to the plastic pulley to align it before the hole
