  3. Off Topic
  4. £95 for a Dt engine?
15 Posts 6 Posters 2.2k Views
  • Irongamer727I Offline
    So I want to kickstart converse my dtx. Found a Dtr engine with a seized 6th gear for roughly £95. Everything else seems to be in full working order. Worth it?
      @irongamer727 you damn right it is even just the engine casings are worth that
      • F Offline
        F Offline
        The kickstart conversion could cost you the most part of £95 so I'd go for it!
          Ye, a kickstart is my final goal for this winter's "overhaul"
          F 1 Reply Last reply
            F Offline
            F Offline
            @irongamer727 easy enough to do once you've got all the bits!
            Just make sure you get the clutch all lined up properly
              It's a 2003 dt engine. Surely the kick should fit without any hassle?
                @irongamer727 Yeah that's fine
                  @calum what do you think about using an impact wrench to unbolt the clutch? And then fastening it again with some locktight applied. It's electric so I highly doubt it will break anything.
                    @irongamer727 Just use the tool, it's like £10 and works on different engines.
                    • F Offline
                      F Offline
                      Yeah I got one from Amazon, it's worked on 3 different bikes so far. Bit of loctite won't hurt of course, I always use a bit on stuff like that
                        @irongamer727 I have an electric impact gun and it swill snap bolts like butter if your not careful
                          @declan ain't any expensive stuff. Doubt it will harm the M12 threads
                          • terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            impact guns don't break bolts people do
                            sorry had to and its true
                            • terry.tzT terry.tz
                              F Offline
                              F Offline
                              @terry-tz reminds me of a Goldie Lookin' Chain song 😂
                              O 1 Reply Last reply
                                O Offline
                                O Offline
                                @finnerz89 said in £95 for a Dt engine?:
                                Haha! Your a poet and didn't know it!
