  3. Does a rich pilot effect riding
38 Posts 4 Posters 8.0k Views
    @irongamer727 just discovered my pilot is a 50 supposed to be a 38 factory must of fitted the wrong jet it’s not a stock bike it’s got a fresh 70cc kit
    @declan also the genuine jets are different so I’ll have to see if the seller will dock me a jet or I’ll just buy one since there pennies 50 is a big jump right?
      @declan could be, different manufacturers use different scales. I would change to stock. What is the big issue? Isn't it running well?
        @irongamer727 I can tell it’s running rich struggles to rev cleanly mainly from no revs to about quarter it splioges oil out the rail pipe and develops a littl splutter when coming off the gas and also struggles for Lower down power
          @declan allright, I think a smaller jet will suffice.
            @irongamer727 well the description of the carb says 38 pilot but it has a 50 in mine so I’ll just get a 38 like it should have and it should be good thank you for your time mate
              @declan so it turns out the pilot was a38 I was looking at the wrong jet lol so I put the one out of the stock carb which iirc is a 32 and it only runs slightly better to get the power right I have to properly lean the af screw out but if I leave it ticking over it needs the smoke clearing out before it can ride even if I leave it for say 30 seconds I’m starting to wonder if I over mixed my 2 stroke oil
                @declan there's only one way to find out!
                  @irongamer727 I guess so 😪 I think I need to find someone that knows jetting tbf to get it spot on
                    @declan what 70cc cylinder? No Airsal I hope
                      @irongamer727 I’m afraid your not gonna like this it’s a 50 pound kit off eBay made in Poland 😆
                        @declan a well, I mean if everything is installed correctly and the reeds etc are fine there shouldn't be a problem jetting it. Have you checked the spark plug? Perhaps it's the culprit?
                          @irongamer727 I put. A really old rusty plug in it’s yhe only one I had the bike starts first kick if I turn the af screw all the way in the bike dies as it should right?
                            @declan make it fair and change to a decent plug. When you turn the screw in you get a richer mixture. (Less air) give the entire carb a good clean.
                              @irongamer727 I’ve cleaned it out properly and yes clean plug will be got and fresh fuel tonight so I know I didn’t screw up the premix
                                Easiest way to figure out if its over fueling is to stifle the intake, if the problem worsens then you got too much fuel, if it improves then you haven't got enough fuel.
                                  @calum if I give it an air leak it runs better
                                    @declan Yeah and risk the engine detonating or inhaling dirt. So you stifle the intake.
                                      @calum I’ll go finger the airbox 2 minutes
                                        @declan Usually gaffer tape part of the air box or socvk over a pod filter.
                                          @calum I put a latex Glove over the snorkel it ran ok on idle but smoked loads and wouldn’t rev much it actually replicated the problem but on a worser scale so maybe the stock airbox is too restrictive? You can barely fit your pinky finger in the snorkel
