  4. DT125R 1994 Running Project
65 Posts 7 Posters 21.1k Views 1 Watching
  • Glynn123G Glynn123
    @declan yeah mate, usually they like a 240 on a full system, I know mine was definetely way lean when it had a 210
    @glynn123 Funny, my DEP was sound on 210 main. It was actually when I fitted a Wøssner Piston did I find jetting an issue, think I needed 280 main in the end to get the jetting sorted. It should be done a bike per bike basis ideally.
    terry.tzT Glynn123G 2 Replies Last reply
      @glynn123 is that the same for other pipes I have a 210 with a full exhaust
      terry.tzT
      terry.tzT
      terry.tz
      @declan just see what you plug says
        terry.tzT
        terry.tzT
        terry.tz
        @calum wow 210 to a 280 that's some big jump how did the performance change
        • terry.tzT terry.tz
          @terry-tz I can't say I noticed a change when I upjetted it, it was purely to get it to not bog out.
          Bit difference with a DEP pipe though.
          terry.tzT 1 Reply Last reply
            Glynn123G
            Glynn123G
            Glynn123
            @calum that's weird, I'm running a wossner piston with 250 main, but I suppose you run open filter rather than airbox don't you?
              terry.tzT
              terry.tzT
              terry.tz
              @calum fair enough
                @glynn123 This was way back when. I may have ran the 3MBP barrel. But whatever it was, I was having difficulty getting the jetting spot on.
                • terry.tzT
                  terry.tzT
                  terry.tz
                  where is to buy main jets from don't want China specials
                  • terry.tzT
                    terry.tzT
                    terry.tz
                    and anyone know where I can get the front gasket from for the carb
                    tunertomT 1 Reply Last reply
                      tunertomT
                      tunertomT
                      tunertom
                      @terry-tz safe rambo, get them from a place called allens performance, theyre genuine mikuni ones so you know they are the proper sizes and not just some stamped up rough chinese uns
                      • terry.tzT
                        terry.tzT
                        terry.tz
                        thanks bud
                        • terry.tzT
                          terry.tzT
                          terry.tz
                          my problem was jetting now rev cleaner through all gears I just lost my head as the problem started a few days before new pipe must have been the old pipe getting too bad stupid of me changed jetting now on a 250 main still not were I want her to be the needle is a bit rich just waiting on a few jets arriving
