  4. DT125R 1994 Running Project
65 Posts 7 Posters 20.6k Views 1 Watching
    I would rather err on the side of tad rich than lean lol.
    terry.tzT 1 Reply Last reply
    • terry.tzT
      terry.tzT
      terry.tz
      any suggestions I'm still having problems with what I thought was full throttle when I'm in 5 gear it bogs seems to be any throttle now before I cleaned the carb it was funny in all gears and 3/4 plus throttle I no there very different symptoms but I'm very sure its the same problem
        terry.tzT
        terry.tzT
        terry.tz
        @calum ye me to but it's hanging a bit too much but I'm going to wait to see what the plugs like in a few days and try to solve my other problem first
        • Glynn123G Glynn123
          @terry-tz you'll want atleast a 230-240 main with Romeu pipe mate, I run a 250, but have snorkel removed from airbox.
          @glynn123 is that the same for other pipes I have a 210 with a full exhaust
          Glynn123G terry.tzT 2 Replies Last reply
            Glynn123G
            Glynn123G
            Glynn123
            @declan yeah mate, usually they like a 240 on a full system, I know mine was definetely way lean when it had a 210
              @glynn123 Funny, my DEP was sound on 210 main. It was actually when I fitted a Wøssner Piston did I find jetting an issue, think I needed 280 main in the end to get the jetting sorted. It should be done a bike per bike basis ideally.
              terry.tzT Glynn123G 2 Replies Last reply
                terry.tzT
                terry.tzT
                terry.tz
                @declan just see what you plug says
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @calum wow 210 to a 280 that's some big jump how did the performance change
                  • terry.tzT terry.tz
                    @terry-tz I can't say I noticed a change when I upjetted it, it was purely to get it to not bog out.
                    Bit difference with a DEP pipe though.
                      Glynn123G
                      Glynn123G
                      Glynn123
                      @calum that's weird, I'm running a wossner piston with 250 main, but I suppose you run open filter rather than airbox don't you?
                        terry.tzT
                        terry.tzT
                        terry.tz
                        @calum fair enough
                          @glynn123 This was way back when. I may have ran the 3MBP barrel. But whatever it was, I was having difficulty getting the jetting spot on.
                          • terry.tzT
                            terry.tzT
                            terry.tz
                            where is to buy main jets from don't want China specials
                            • terry.tzT
                              terry.tzT
                              terry.tz
                              and anyone know where I can get the front gasket from for the carb
                              tunertomT 1 Reply Last reply
                                tunertomT
                                tunertomT
                                tunertom
                                @terry-tz safe rambo, get them from a place called allens performance, theyre genuine mikuni ones so you know they are the proper sizes and not just some stamped up rough chinese uns
                                • terry.tzT
                                  terry.tzT
                                  terry.tz
                                  thanks bud
                                  • terry.tzT
                                    terry.tzT
                                    terry.tz
                                    my problem was jetting now rev cleaner through all gears I just lost my head as the problem started a few days before new pipe must have been the old pipe getting too bad stupid of me changed jetting now on a 250 main still not were I want her to be the needle is a bit rich just waiting on a few jets arriving
