  4. Vforce reeds
Vforce reeds
23 Posts 10 Posters 10.7k Views 1 Watching
  • 2
    2stroketerry
    Vforce 4 from a Yamaha blaster quad fit, just need to move the holes slightly inwards as in pictures 2 &3 but they do make a big difference.
    R 1 Reply Last reply
    4
    • 2 2stroketerry
      R
      R
      ryanjimccfc
      @2stroketerry do you just drill different holes a do you have to fill the old ones in with something
        Did not know that. Nice one Terry.
        • P
          P
          PJT95
          wrote on last edited by PJT95
          I'm looking to get a reed block, is there any particular model of blaster that this comes from?
            88-97 Honda CR125 or WR200 reed block are the way to go,
            But obviously, you will need to modify the bolt pattern to suit the DT crankcase,
            I’m unsure of any benifits on a Standard DT top end tho,
            Buy an Ignition first!
            R
            R
            ryanjimccfc
            @darty what ignition would you recommend
            • Louis-DT-WRL
              Louis-DT-WRL
              Wondering if the v4 is any better than my V3 block, I have to say it revs off the clock with no spluttering unlike the standard block did
              • R ryanjimccfc
                He was using the dt200 engine dident he
                Louis-DT-WRL
                Louis-DT-WRL
                @ryanjimccfc said in Vforce reeds:
                No my original engine that came with the 125r had vforce the V3 block first with small modifications. Then built a custom engine with a sc125 (same as Yamaha dt125re ) engine with a wr200 cylinder,head, PV and crankshaft. Mikuni tm34ss carb, V3 vforce reedblock, open air box, zeeltronic reprogramable cdi, custom larger radiator and wr200 dep exhaust system.
                The V3 block rules, revs out off the clock incredibly smooth and eliminated spluttering
                • 2
                  2stroketerry
                  The Vforce 4 On average they gain 0,4 a 0,5HP more and let the engine rev about 200 a 250rpm longer compared to a modified set of of standard reeds.
                  • 2 2stroketerry
                    @2stroketerry Can't say I've had any rev limiting issues on my DT, maybe not riding it hard enough or not tuned enough.
                    • stinkwheelerS
                      stinkwheelerS
                      stinkwheeler
                      I have some here that fit a dt perfect like they were made for it i think there for a ktm the only difference is the stuffer hole is slightly off
                      • stinkwheelerS stinkwheeler
                        scrimsmustang
                        I have YFS200 blaster vforce4 in my DT175/225MX, they just fit straight in bike has a stroker blaster crank blaster topend, i think they would be a bit narrow for a dtr. Wr200 might fit with a bit of moding. I have a DTR/YZ 125 engine running standard reeds with one and a quarter sets of petals to prevent high rpm flutter. Modded yz inlet rubber just to bolt holes need drilling and a bit trimmed off the right hand side, a modded open top dtr airbox with yz carb to airbox rubber with yz carb runs great
                          @ryanjimccfc Yeah, I'm not aware of any V-Force Reed blocks fitting these engines.
                          I know @louis fitted one to his DTR, but he is running a completely different engine.
                          stinkwheelerS
                          stinkwheelerS
                          stinkwheeler
