  3. Oil Questions
Oil Questions
40 Posts 9 Posters 18.7k Views 1 Watching
  • Irongamer727I
    @ninja Alright thanks. Transmisson oil then?
    What do you run?
      What do you run?
      @irongamer727 Silkolene 75W-90, is what I have just put in my Starlet. Think it was around £75 for 4 litres.
        @calum and your DT and RS?
          @irongamer727 Castrol GTX Semi Synthetic lol.
          I'll probably go with Silkolene for the RS, but the DT only ever got Castrol. I was on a budget at the time. And the DT doesn't make any power, plus engines were ten a penny.
          • Irongamer727I
            https://www.google.com/search?q=silkolene+10w40&client=ms-android-samsung-gs-rev1&source=android-browser&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiPof6uhrvbAhUCPVAKHXJVDgoQ_AUICSgB&biw=360&bih=564#imgrc=vv-x_zgaF1AhSM:
            This is good stuff then? Reasonable price as well.
              Yeah I can't comment. Great on my starlet but as said only ran semj synthetic castrol on the dt
                @calum well I'm after good quality stuff. It's got the right classifications.
                  @irongamer727 Yes, but I have had good oils mess with my clutch before. Castrol magnetec cause the clutch to slip uncontrollably
                    @calum but mate it doesn't have the right classifications. Can't say I'm surprised really.
                      @irongamer727 Ey? What doesn't Magnetec? Does it say don't use with cork clutch plates lol
                        @irongamer727 your being wayyy too picky with your oil just grab some for wet clutches at a good price I’ve used the cheapest oil money can buy in my 4 stroke and I liked the stuff the best cheap oil I used was Tesco’s own brand it was genuinely good oil
                          I mean, I wouldn't put cheap stuff in, but I wouldn't overthink it either.
                            @calum yeah but there’s really not much into it especially for a 2 stroke I’m just saying some of the best oil I’ve had was Tesco’s and that wasn’t dirt cheap but was still an ok price
                              @declan Good oil can and will prolong the life of the engine. That's my only concern.
                              Cheap oil, no thanks.
                                #37
                                @irongamer727 like your ever going to tell, but if you want the best of the best they buy the most expensive oil you can find then I guess there’s no room for doubt
                                  Its almost impossible to wear out the transmission on our bikes, so its fine as long as it meets the specifications.
                                  I cant remeber the interval for changing the oil, but its rediciously high. Most will change it way before, so the oil have an easy life. Just about any oil on the marked will exceed the specifikations on our bikes, which were basically designed in the 80's.
                                  So yeah, dont overthink it. 🙂
                                  • J Jens Eskildsen
                                    @jens-eskildsen thank you 🙏
                                    • 2
                                      2stroketerry
                                      Always used Silkolene Comp 2 which is best oil there is either premix or injector oil.. £38.90 for 4 Litres so £9.72 per Litres https://www.ebay.co.uk/itm/Silkolene-Comp-2-2T-2-Stroke-Motorcycle-Engine-Oil-4-Litres-4L/161276818881?epid=10017008607&hash=item258cd8f5c1:g:NEQAAOSwcwhVP4E0
