  3. DTRE
  4. Yamaha dt125re rebuild
92 Posts 13 Posters 34.5k Views 1 Watching
  • B
    B
    BraDT
    #37
    Banked holiday over and got the frame paint swingarm and few other little bits done it’s now to start putting back together and find out what needs replacing
      Looking sweet bud.
      • B BraDT
        @bradt Black is the new black I see!!! :face_with_stuck-out_tongue_winking_eye:
        • B
          B
          BraDT
          Easy colour to paint with and hides tho slight imperfections photos don’t show the shine enough will get more pics when forks and wheels are on
          • B
            B
            BraDT
            Right I’m stuck, confused and baffled
            I’ve taken the starter motor off with having problems of the annoying clicking noise new battery new relay all wire checked cleaned etc so I know it’s something with the starter
            Should I be able to move this cog by hand ?
            It doesn’t move at all could this be my problem?
            https://i.imgur.com/Ll9LnEz.jpg
            • B BraDT
              @bradt I don't think you should be able to move it by hand IIRC.
              • B
                B
                BraDT
                #43
                Well starter motor been cleaned down etcand put back on engine fingers crossed
                Engine back in bike now with front front forks and wheel
                Finally getting somewhere
                  That's looking decent mate!
                  Nice job.
                  • B
                    B
                    BraDT
                    @calum cheers mate
                    Right tonight after work I am changing the gear selector seal any tips or step step guide ?
                    Isit a case of digging the old one out and tapping the new one in ?
                    • B BraDT
                      @calum cheers mate
                      @bradt Easier to do when there is no gear lever in the way mate.
                      You will risk damaging the shaft and causing a permanent oil leak.
                      IIRC, it should not be difficult to remove the gear lever out put.
                      Whip the clutch cover off and remove it. Then remove the seal, then replace the seal, then replace the lever. IIRC.
                      declanD B 2 Replies Last reply
                        @calum I do mine with the shaft still in and it’s way easy bud
                        • B
                          B
                          BraDT
                          @declan any tips ?
                            B
                            B
                            BraDT
                            @calum cheers mate sound complicated lol
                            • B BraDT
                              @bradt It really isn't shaft just pulls out, giving you clear access to the oil seal.
                              • B
                                B
                                BraDT
                                @Calum so clutch cover off any need to remove the clutch basket or anything else?
                                Really didn’t wanna tip the engine apart on this build wanted it to be simple and learn as I go but I have learnt it will never be a simple job 🤣
                                • B BraDT
                                  @bradt If you damage the shaft, it will always leak oil and you will need a new shaft. It's just hacky to do it in situe, but can be done.
                                  I can't remember how it is on these engines, what is in the way.
                                  But that should be pulled out from the clutch cover side. You don't need to remove it, just pull it clear of the oil seal so you don't damage it.
                                  • B BraDT
                                    @bradt I just levered it out with a small flat head cleaned up then pushed the other in I didn’t do nothing special but taking out the shaft is sensible just not for me
                                      Id just replace it aswell, its pretty common to do, And I've done so many times on other bikes, both for the gear selector shaft, and the main output shaft.
                                      • B
                                        B
                                        BraDT
                                        Got it sorted removed the shaft like Calum said wasn’t to hard but that another box ticked on the list
                                        • B
                                          B
                                          BraDT
                                          #56
                                          So got back from work yesterday to find out the other half has been shopping for me and started without me
                                          So she has painted my Caliper in blue and my brackets in black
                                          Deffo a keeper this one 👍🏻
