  4. What temp should a dtr125 run at
31 Posts 8 Posters 8.4k Views
  • MiniaM
    MiniaM
    Minia
    You shouldn't need to really worry until it sits at more than 105 or so.
    • MiniaM Minia
      @minia mine sits at 100 at the cap so I guess mines overheating? I don’t get coolant over boil
      CalumC MiniaM 2 Replies Last reply
        @declan As I say, pressure needs to exceed 1.3 bar, which is massive. If you imagine my car only generates 0.8 bar of boost pressure.
        This is a why waterless coolant has its benefits. 1.3 bar of pressure is exerted on the entirety of your coolant system. It's going to be mainly the radiator that will take the most damage. The drawback is that the specific heat capacity of it is less, resulting in higher operating temperatures.
          @calum have you seen the workshops videos on yt about waterless coolant I wouldn’t touch the stuff it’s a good listen either way if you get free time
            MiniaM
            MiniaM
            Minia
            @declan You're not overheating as long as your engine and coolant system still run efficiently. Keep in mind when water is pressurised it requires more energy for it to boil, which is why if you're riding hard on a bike your thermometer might say 105 celcius, but actually it's fine because it is pressurised and therefore your boiling point is raised.
            And besides you will feel it if your engine is struggling, it will smell hot, you'll lose power, you'll hear it struggle at lower rpms etc
            • MiniaM Minia
              @minia it’s not something that worries me tbh I ain’t rode it in ages it’s rotting on the garden sadly
                Normal, what is normal? Outside temps vary by 20c theese days where im located. You'll have a hard time to reach 70c at the cap in the morning just cruising around, and having a hard time not to exceed 110c at the head in the afternoon on a tight track. Some valid points to where you meassure, temps will read higher in the head, compared to on top of the radiator.
                Waterless coolant boils at higher temps, but something like Evans actually remove less heat from the engine, so...whats the point of that? I've never heard of anyone damaging a radiater due to cooling preassure. 1,3 bar isnt normal running pressure, but maximum pressure, before the cap lifts and "bleeds of" the excess. If you're worried, buy a cap with less pressure.
                Unless it boils, its fine. Bike is designed to function with 100c or more coolant, otherwise it wouldnt have a 1,3bar cap on. Everyday use should be less of that, ofcourse. But the thermostat isnt even fully open at 80C, come on people...
                Unless something is off, its also just about impossible to get detonation in our bikes with super low compression. I've ridden mine on 20% diesel as part of a bet, no issues.
                Theres always small exeptions for modified engines, which generate more power and heat, but that goes for any engine.
                  Btw, isnt our stock cap a 1,1? Thats what I recall anyway.
                  • J Jens Eskildsen
                    @jens-eskildsen 1.3 on my Starlet, I've been away from my DT so long I can't even remember.
                      Found one on ebay that said 1,1 and listed as beeing for a dt125r 🙂
                      • J Jens Eskildsen
                        #25
                        @jens-eskildsen yeah I don’t get Evans because people say it’s safe because you don’t overheat well yes you do it’s just the coolant doesent boil until such a high temp id much rather it boil over as then I know something is wrong rather that having a full rad but a melted piston
                          @declan It's not about overheating. It's about the pressure not building up in your coolant system. It's a trade off at the end of the day. And since it's not water, it doesn't oxidise and rot your engine. Our engines are Aluminium, but on a car with a steel block it makes more sense.
                          You need to take into all the factors into account.
                          For something you are going to use once in a blue moon, it makes sense since you don't need to drain the coolant system for periods of storage.
                            @calum that’s about the only thing that makes sense to me
                            • Glynn123G
                              Glynn123G
                              Glynn123
                              With radiator cap sensor my DT runs lowest 60 degrees and highest 80 degrees, whatever the weather. Thats with the stat removed and a shitty dented up radiator, when my headgasket went I had it to 110+ degrees about 4 times just from the steam from the engine boiling under pressure, so im guessing it was alot hotter, never got tight luckily.
                              • Glynn123G Glynn123
                                @glynn123 Shouldn't run an engine without a thermostat bud, really bad for the engine.
                                Glynn123G 1 Reply Last reply
                                  Glynn123G
                                  Glynn123G
                                  Glynn123
                                  @calum how so? gets up to temp quick and stays stable at 70 degrees most of the time, coolant circulates good and expands appropriately.
                                    @glynn123 The thermostat provides several features. And the one you're referring to is the less significant one.
                                    Yes the thermostat allows for quicker warming up of the engine, prevention of a heat seizure when the radiator dissipates too much heat, but that is only part of the story.
                                    The thermostat also acts as an intentional resistor in the water jacket. It will prevent stale, localised boiling, of coolant within the jacket, by pressursing the water. Thus the exchange of coolant is made causing any boiled pockets of gas to be moved on and either vented out through the radiator cap, or through the rest of the cooling system.
                                    This feature stops the cylinder distorting, or more importantly, the cylinder head, where most the heat will occur.
