  4. Clutch
Clutch
67 Posts 7 Posters 27.0k Views 2 Watching
    NORFE used to chop up some M6 bolts and use as a bearing....
    Not sayinf that's good practice but was good enough for him.
    RickyR
    RickyR
    Ricky
    @Calum I've got some old bearings I was thinking of opening them up see if any are the same size the rods are ok
    DT 125X
      @Ricky That doesn't look great lol.
      You can get the ball bearings off eBay for next to nothing..
      RickyR 1 Reply Last reply
        RickyR
        RickyR
        Ricky
        @Calum I've ordered 1 from yambits I was playing with the bearing idea as there can't be any difference surely
        DT 125X
          I should not have thought so, but as said the correct ball can be had off eBay.
          • RickyR
            RickyR
            Ricky
            Probably a daft question but with the bike off and my clutch pulled in should it freewheel or turn the engine over slightly when pushing it
            DT 125X
            • MightymanM
              Very normal for it to turn the engine.
              • MightymanM Mightyman
                RickyR
                RickyR
                Ricky
                @Mightyman so it wouldn't be normal if it didn't
                DT 125X
                • MightymanM
                  Well in theory it shouldn't.. but I've found they always do.
                    Yeb, cold oil is thicker and "sticks" more, so the clutch stil drags a bit.
                    • B
                      B
                      Bananper
                      Did you figure out the cause of this problem?
